Question about Cuisinart DGB-600 Coffee Maker
Wont brew a full pot
When i turn the coffee on it will grind the coffee but then will only brew 1 to 4 cups at a time im not quite sure what to do about this please help
  • 2 more comments
  • theresa galt May 15, 2007
    just an update ive pushed the 1to 4 cup button and it will brew a full pot as long as the button is pushed i think it is just confused
  • Anonymous Nov 03, 2007
    Brews two cups and done
  • Anonymous Nov 16, 2007
    I have the same problem as does my neighbor. There must be a product defect here.
    I cleaned the machine and filter as recommended in the manual to no avail.
  • memo1234 Nov 25, 2007
    I have the same problem. I hate this coffee machine. I have to retrun to this machine 10 times in the morning.
I had the exact same problem with my machine making 1 cup at a time.
Here is the solution:
1. make solution of 1 part vinegar & 2 parts water.
2. pour solution into resivoir and set for 2 hours
3. run solution through machine (yes, you will have to stand there and keep pushing the buttons).
4. take same solution (now very hot) and run it through machine 5 or 6 times
5. make fresh solution and continue process until machine runs full cycle.
Posted on Oct 19, 2007
  • Rosalie Grams
    Rosalie Grams Dec 16, 2017
    I have done this and also some cycles of Lemishine. Still won't make a full pot. I unplugged the machine overnight to see if there was a reset issue. That didn't help. Machine is used lightly once per week and only filtered water. Cleaned and dried after each use. I am disappointed.
After getting up two or three times every morning to go downstairs and keep pushing the button, I had had enough. I filled it 1/2 full of vinegar and 1/2 full of water. This thing was either going to work or get pickled. After running it through 3-4 times, it started brewing all of the water through.
Posted on Mar 26, 2008
I have the same problem and can't figure out why it is doing this. The 1-4 cup button only double heats the water.
Posted on Jun 11, 2007
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Won't make full pot
Okay, try this, make sure that everything is cool first, then take a turkey baster full of hot water and vinegar and shoot it backwards through the coffee maker...where the water falls on to the grinds. After that, try running either a commercial coffee pot cleaner or just again, vinegar through the brew cycle with no coffee in there. Try it two or three times, there may be calcium buildup in the filter and pump. You could also try that CLR cleaner, but make sure you rinse the pot out really good, and run a few cycles of just water before you drink anything from it.
Hope this makes sense and helps you out!
Jan 12, 2009 | GE Coffee Makers & Espresso Machines
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a automatic grind and brew. It will only brew a full pot of coffee if I turn it on four cups. That wasn't to bad but now Ihave to unplug it to get it to come on.
Unplug for 20 minutes to fully reset, then:
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Product is not completely brewing all of the water - it takes 3 times to brew a full pot of coffee. very frustrating.
Having the same problem. It's a thermostat issue. The product seems to have three. Trying to figure out which one is causing the problem.
Aug 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Does not brew a full pot anymore.
Sep 01, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
314 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
