TV PSU high speed ticking noise
Hi My friend has a Techwood 32" LCD TV, broken screen. Just checking the parts from inside to see if he can sell it, found Vestel brand Power Board 17PW25-4. The TV switches ON and the inverter, backlight, main board works fine as well, can hear the sound and the the broken distorted pic, but the meaning is that all things work. The only thing is that the Vestel Power Supply makes high speed ticking noise while the TV is trying to switch ON. Once the LED stays ON, the ticking sound does not disappear but slows down quite a lot. From standby to bring the pic ON also brings the ticking sound back ON until the pic comes on and then the ticking goes a bit low. As the PSU seems to work fine but the ticking still there, what component is kind of faulty, where should I check for the fault. The reason is as everything works I dont know what to do and where to look for the fault. Thanks
  • Raks Oct 30, 2012
    Anyone to help?
4 Suggested Answers
  • 133 Answers
SOURCE: Screen goes completely out.
when it blanks out, tuen the lights out in the room, and shine a flash light at the screen, see if you can see the picture, if you can, it is the inverter moard blamking out, thats the board that lights the back lights, if you cant, hit the input button on the remote, if the TV comes back with a picture, it is a problem with the main board, in paticular the componant input on the main board
Posted on Jan 10, 2009
  • 21 Answers
SOURCE: LCD TV, No Power, No Standby LED, Buzzing sound from Power supply
sounds like either way your power board is bad- do you intend on replacing a component? I would look for Puffy caps- you know- leaking from the top-
Posted on Aug 21, 2009
vinceisaac
  • 2432 Answers
SOURCE: Sharp Aquos LC-C3237U no picture backlight OK green light on
check if their is a signal on voltages around 3.3v at the inverter board if none their is a problem in the board which is in the processor.
Posted on Aug 31, 2012
My problem is my TV a phillips 32 has broken screen
Whenever a LCD screen has been damaged, it's not going to be cost effective to repair. The part will cost you nearly what the replacement cost of a new T.V.. Sell the good parts that are inside your T.V. on Ebay.
Oct 01, 2012 | Philips 32PF5320 32 in. HD-Ready LCD...
My techwood 22inch tv lcd screen is broken due to being knocked off stand is it repairable?
If the screen is physically broken or cracked, as it is organic electronics inside, no. A replacement is the answer but it is probably cheaper to purchase a new TV.
Hope that helps.
Nov 21, 2010 | Televison & Video
I have two lcd tv with the screen broken and another with the electronic destroid . all the 3 are 32 inc lcd but made by different producers. Can i substitute the broken screen with one of those with...
You will not be able to mix match parts to make one TV even though they are all 32 inches. Technology and applied differences are vastly different between all the TV manufactures.
You could try to sell your 3 broken TVs for parts and then put that money towards the purchase of a new TV.
Good luck.
May 24, 2010 | Televison & Video
My lcd tv 32pfl5332 broke the lcd screen what should I do?
Sorry it junk,sell it on Ebay.com for parts or save it for parts for the new purcharse tv with the same model.U can try Shopjimmy.com for some tv 32"LCD screen,but don't if they have Philip LCD or LCD work with Philip LCD tv models.But basicly LCD broken in 40 and up is not possible to get LCD screen.Tv compannies sell LCD Screen out the same as a new tv price or well exceed the price after part and labors.
Feb 04, 2010 | Philips 32PFL5332D 32 in. LCD Television
Olevia 32" lcd tv made a loud, popping noise, shut off & now it won't come back on. When it popped, I noticed a spark
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Feb 03, 2010 | Olevia LT32HVM 32 in. LCD Television
My samsung lcd tv has a crack any idea on cost of fixing
Not possible to change,bcause tv companies don't sell out LCD Screen,If they do sell it to u,it cost about the same as a new tv.There hundred or more parts for LCD tv,some came from LCD broken or damages.
Dec 11, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Need a sharp 32 LC-32SB21U screen
Manufacturer Sharp Part Number LK315T3GW30R Description 32" VE PANEL ASSEMBL
Sep 04, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Broken Screen on Plasma TV
Broken Screen on Plasma TV A broken TV screen can not be fixed. A replacement sceen can cost as much as a new tv since the new set prices keep falling. You can sell the unit for parts. (ebay?)
You can get a screen protector from;
http://www.tv-armor.com/
or fashion your own.
May 09, 2009 | Akai LCT3285TA 32 in. LCD Television
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
