Question about Air Tools & Compressors
How do I use a Coleman Powermate PMJ8160 (jump starter, air compressor) to jump start my car? Does it need to be plugged into a charger (car charger plug is all I have) because it won't jump my car right now!!!
  • 104 Answers
SOURCE: coleman powermate inflationmate pump
The ring is gone on compressor. You can buy replacement pistons and rings from colemen. Comes with instructions.Good luck
Posted on Oct 26, 2008
  • 65 Answers
SOURCE: coleman compressor no build up of pressure
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Posted on Dec 03, 2008
  • 1388 Answers
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
Posted on Jan 10, 2009
SOURCE: Need a manual for a Coleman Powermate air compressor Model #VP0200608 Elec.
I'm looking for a owners manual for a colman powermate air compeser modle cl0502710
Posted on May 04, 2009
  • 7 Answers
SOURCE: i need an operators manual for a Blue Max
Go to hondaengines.com and down load the manual you need
Posted on May 08, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Can a Duralast jump starter kit start a car while plugged into an outlet?
The charger to a Jumpstart charges at a low rate (300mA to 500mA) and will not push enough current to start a car. Best to have Jumpstarts recharged every 6 months to be ready for emergency.
Nov 26, 2012 | RoadPro Road Pro 12 Volt Dc Portable...
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Need a charger to charge my Jump Starter BP-DLG
Need confirmation that the AC adaptor for Duralast jump start model BP-DLG is a 12volt 450ma. Is this correct or do I need something else?
Nov 06, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Will not start
Hi
Keep it simple, have you pushed the reset button?
Ther may also be a master push / pull switch on the switch housing.
Aug 09, 2009 | Coleman Powermate 02 - Gallon Air...
Apr 18, 2009 | Air Tools & Compressors
Coleman compressor no build up of pressure
Oct 28, 2008 | Coleman Powermate 02 - Gallon Air...
Air Tools & Compressors Logo
292 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
