Question about Frigidaire Affinity Glacier Blue 3.5 Cu. Ft. I.E.C. Capacity Front Loading Washer, ATF7000EG
Just got the washer--makes a buzzing noise
Just got the Frigidaire washer, and in our first load it's making a buzzing noise after it got into one of the higher cycles. It's not a mechanical buzzing noise, but rather sounds like that of an alarm. I can pause the load and after hitting resume the noise begins again. Did I forget to take out some sort of precautionary plug or something? Water seems to be filling and draining normally, and operation seems to be normal except for the noise. Thanks
  • smog Nov 21, 2007
    mine does the same, buzzing towards the end of each cycle. It sounds like a 60 Hz electrical buzzing from a solenoid or something. Coming from the door lock area, but not correlated with the door lock cycle. The noise comes and goes smoothly as if the machine is gradually applying more and less voltage. If the door is wiggled or pressed on lightly, it affects the volume of the noise. Pausing cycle stops the noise although the door is still locked, resuming causes the noise to return.
    President:
  • 1,294 Answers
Try some anti-sqeek or soap on your washer belt.
Posted on Sep 04, 2007
  • prem mathew Sep 04, 2007
    It could be just a dry belt and pulley.
    You could try the old squeeking car fan belt trick and rub soap on the belt. You can even buy sticks of anti-squeek from automobile outlets.
    An unlikely thing would be the transport supports; be sure you have dismantled certain things behind the machine; according to your manual before you plug in. These struts are put in to prevent the drum from moving while in transit.
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Makes a loud buzzing noise when attempting to start cycle
The lock solenoid on the door latch assembly may be hanging up or just noisey. If washer starts and runs then all is ok. If washer wont start, just buzzes, then door latch assembly may have to be changed.
Feb 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Buzzing - will not spin or drain water
This noise is probably the pump trying to start but will most likely be obstructed.Drain the machine manually by lowering the drain hose into a bucket or bowl and then remove blockage.
Nov 07, 2008 | Frigidaire ATF6000ES Front Load Washer
My washer is making a buzzing noise and stopping the process.
Yes sounds like the drain pump or sump area is clogged. Axcess throug lower service panel if the model you has selected is accurate..
Jan 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
970 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
