Question about Buffalo Technology 320GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD Hard Drive
My HD-PC500U2/BK-AP hard drive does not respond when it is connected to my laptop. No light, no sound, none at all. Can it be fixed?
4 Suggested Answers
AldRezaine
  • 995 Answers
SOURCE: External Buffalo Hard Disk 500 Gb model no
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Posted on Dec 18, 2009
  • 10406 Answers
SOURCE: When i connect Buffalo Mini
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
socialone75
  • 82 Answers
SOURCE: I have a HD-CE1.0TU2-AP Buffalo
Sounds like the drive might be taking a dirt nap.
You've a lot of really great freeware options for file recovery if you're running Windows. Notable apps include Undelete Plus (original post), PC Inspector File Recovery (original post), and Restoration (original post). Undelete Plus is the most user-friendly option of the bunch, with advanced filtering options that make it easy to find your needle of a file among the haystack of deleted garbage, but in my tests I found both Restoration and PC Inspector File Recovery to be more effective at recovering files. (Of course, your mileage may vary.) As an added bonus, the bare bones Restoration is portable, which makes it an excellent addition to your thumb drive.
Posted on Mar 01, 2011
Why is my laptop not recognizing imicro IM25COM-BK?
imicro IM25COM-BK is an external Hard Drive for USB 2.0. 1. Did you install the Driver which came with your Drive? 2. Are you sure it is connected to an USB 2.0 port? Some computers come with USB 1.1 !
May 17, 2014 | Imicro 2.5 SATA/IDE ENCLOSURE BLACK...
No power
A) Check the transformer/ power lead with a multimeter
B) If fail then Buy new power supply
C) If succeed then Smile
D) If not smiling then contact disk recovery specialist www.data365.com.au
Nov 30, 2013 | BUFFALO hop HD-PX500U2/BK 500 GB USB 2.0...
I replaced the HD on EEEPC 1005PE and now the video screen will not power up at boot. All connections seem tight.
When replacing your hard drive, you reinstall your operating system or you can't boot your pc.
Mar 05, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have a HD-CE1.0TU2-AP Buffalo 560GB hard drive. I have just plugged the drive into my laptop, and the green light just blinks rather than it being constantly on. The drive is also not spinning, the...
Feb 27, 2011 | Buffalo Technology Computers & Internet
Keyboard not responding using onscreen keyboard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 17, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
When i connect Buffalo Mini Station HD-PF500U2/BK-AP to my laptop, the green signal blinks with beep sound and thereafter, the device is not detected. How can i solve this problem. I have important...
* the USB cable
* the power-adapter
Nov 11, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
External Hard Drive won't respond
ok 1. you need to be sure that you can`t have acces anymore by usb to the external HD... try in another machine example a other laptop.. or you need to open the HD and connect to other way with a new conector that sell in comusa or other computer store... pls click that my solution was usefull
Dec 27, 2009 | Acomdata E5 HD320UHE5-72 320 GB USB 2.0...
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
The Laptop Wont Even Start
Acer has the tendancy to blow it's regulator circuit, it makes a fast tik-tik-tik sound, if so, send in for repairs, nothing you can do to fix it. JJ
Sep 11, 2007 | Acer TravelMate 2355LCi Notebook
Open Questions:
recording from an external hard-disk to a DMR Dear Sir or Madam, I have just purchased the DMR-BST835EG Blu-Ray Recorder, which has many attractive features. In fact, I also recommended this product to a friend of mine. My prime intention is to transfer some Internet downloaded .MKV-HD and .MP4-HD movies, presently stored on a Buffalo USB-powered external hard-disk, onto the Panasonic recorder's internal (1TB) hard-disk. However, after registering the said USB-HDD on the DMR, its driver is no longer recognized on my computer...and it has to be re-formatted via the PC, with the result that the Blu-Ray recorder again refuses to copy video files from it. What can I do? This article (the DMR) was purchased, for over EUR 600, from EBay, mainly for the above-stated purpose, repeat: copying the HD films, presently kept on external hard-disks, onto the Panasonic recorder (so as to transfer the files onto Blu-Ray discs later on). Please treat as urgent, as I would like to start using the Panasonic article accordingly, and my friend also needs this information before buying the DMR-BST835EG (too). I earnestly await your reply. Thanks in anticipation for your time and attention. Best regards, Ivan Micallef P.S.: Is there some firmware update which could enable the USB-HDD >> HDD (1 Terabyte) recording ? This is an option which should be possible, also according to the DMR's "Copy Video" menu. ; According to various website blogs, many other clients are facing the same problem - what we are askingfor is for the elimination of the USB-HDD registration request. ; Preferably, the external hard-disk accepted/recognized by the Panasonic DMR should remain in the NTFS format and not changed to the FAT32 system. Thanks again.
Mar 13, 2014 | Buffalo Technology 320GB MINISTATION TURBO...
See all Buffalo Technology 320GB MINISTATION TURBO USB 2.0 Questions
Buffalo Technology 320GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD Hard Drive Logo
160 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
