Question about MSI MS-6734-10 (-6734-010) Motherboard
Ich hap probleme mit dem mainboad MS-6734 M-ATX Mainboard
Da wird nicht geschrieben wo der M/B switch hinkommt ?
bitte helft mit !
    Scholar:
  • 58 Answers
Hallo,
was genau meinst du mit M/B switch ? -> LAN Switch (einfach an die Netzwerkschnittstelle)
this is the board: (?)
Here the link to the manufacture:
http://www.msi-computer.de/index.php?func=proddesc&prod_no=558&maincat_no=1#
Hier zum Handbuch:
1.5 English 3291KB E6734v1.5.zipDirektlink:
http://download2.msi.com.tw/files/downloads/mnu_exe/E6734v1.5.zip
Posted on Jan 06, 2009
  • Gerhard Stoll
    Gerhard Stoll Jan 06, 2009
    Specifications
    CPU
    • Supports AMD® Athlon™/Athlon™ XP/Duron™/Sempron™ processor
    • Supports up to Athlon™ XP 3000+ processor
    • FSB@200/266/333MHz
    Chipset
    • VIA® KM400 Chipset
    - Supports 200/266/333MHz front side bus
    - Supports DDR200/266/333
    - Supports AGP 4X and AGP 8X
    - Integrated S3 Graphics UniChrome™ 2D/3D Graphics with motion compensation
    • VIA® VT8235 Chipset
    - Integrated Direct Sound AC'97 audio.
    - Dual channel Ultra DMA 33/66/100/133 master mode EIDE controller.
    - ACPI & PC2001 compliant enhanced power management.
    - Integrated USB 2.0 controller.
    - Integrated LAN MAC.
    Main Memory
    • Supports four memory banks using two 184-pin DDR DIMM.
    • Supports up to 2GB PC1600/PC2100/PC2700 DDR SDRAM.
    • Supports 2.5v DDR SDRAM.
    Slots
    • One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot.
    • Three 32-bit PCI bus slots (support 3.3V/5V PCI bus interface).
    On-Board IDE
    • An IDE controller on the VT8235 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and
    Ultra DMA133/100/66 operation modes.
    • Can connect up to four IDE devices.
    Audio
    • AC'97 link controller integrated in VIA® VT8235
    • RealTek ALC655 6-channel audio.
    - Compliance with AC'97 v2.3 Spec.
    - Meet PC2001 audio performance requirement.
    LAN
    • VIA Fast Ethernet LAN.
    - With external VT6103 Fast Ethernet PHY &10/100 Base-T Lan transformer.
    - Integrated Fast Ethernet MAC and PHY in VT8235.
    - Supports 10Mb/s and 100Mb/s auto-negotation operation.
    - Compliance with PCI v2.2 and PC99 standard.
    - Supports ACPI power management.
    On-Board Peripherals
    On-Board Peripherals include:
    - 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes.
    - 1 serial ports (COM A) and 1 VGA port.
    - 1 parallel port supports SPP/EPP/ECP mode.
    - 6 USB 2.0/1.1 ports (Rear x 4/ Front x 2)
    - Vertical audio ports
    - 1 RJ-45 LAN jack
    BIOS
    • The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and
    expansion cards of the board automatically.
    • The mainboard provides a Desktop Management Interface (DMI) function which records
    your mainboard specifications.
Originaldruckerpatrone wird nicht erkannt
Sicherstellen, dass die Lexmark Patrone ist nicht leer.
Versuchen Sie, die Patrone in den Drucker neu ein. Bitte folgen Sie den Schritten unten:
1. Entfernen Sie die Patrone aus dem Drucker.
2. Schließen Sie die Druckerabdeckung.
3. Ziehen / re-Stecker des Druckers in die Steckdose, um es zurückzusetzen.
4. Wenn der Drucker eingeschaltet wird, setzen Sie die Patrone.
5. Wenn der Fehler erscheint, versuchen, einen anderen bekannten Arbeiten zu bestimmen, ob es sich um eine fehlerhaftePatrone Problem ist einzufügen.
Wenn Ihr Original Lexmark Patrone gefunden fehlerhaft (nicht leer), kontaktieren Sie bitte Lexmark Technical Support Centerfür weitere Unterstützung.
Hinweis: Dies ist übersetzt mit translate.google.com.
Aug 24, 2011 | Lexmark P350 InkJet Photo Printer
I need drivers
Sehr geehrte Damen und Herren,
ich bitte Sie um Hilfe für einen Treiber für meinen Mini-DV-Panasonic-Camcorder NV-GS17
(24 x optical zoom)-weil ich sonst keine DV-Inhalte auf den PC übertragen kann,-weil der
o.a.Camcorder nicht vom System erkannt wird!Eine Verknüpfung wird nicht anerkannt!?
Oder gibt es eine andere Lösung für mein Problem???
Ich danke Ihnen sehr für Ihre Hilfe,-mit freundlichem Gruss......Helmut Scholz
P.S.:Mein System ist:Windows 7-64 Bit/ DANKE !
Aug 12, 2011 | Panasonic NV-GS17 Mini DV Digital...
Wenn ich den Zylinderkopf ausbaue muss die oelwanne ab und muss der Motor nach vorn heraus gezogen werden
Ich bin traurig, wenn dieses schlecht geschrieben wird, da ich nicht Deutsches in einiger Zeit gesprochen habe. Nicht muss die Maschine nicht entfernt werden, wenn den Zylinderkopf entfernen Si. Auch ich verstand nicht das Teil ?ber die ?lwanne.
Jun 09, 2011 | Chrysler 300C Cars & Trucks
Hallo wie kann man die uhr bedienen
  • Ich nehme an, Sie haben die Cobra 2000 als das ist die einzige Cobra-Modell mit einer Uhr auf.
Um die Uhr auf sie diesen Schritten folgen -
Time Set - 3 Switches (zur Zeit eingestellt) Dynaalert - 3 Switches (zur Alarm-und Radio) Counter / Clock - 3 Switches (zur Anzeige auswählen)
TIME SET Time Set Switch - Drücken Sie diesen Schalter mit Stunden-Schalter oder Minute-Schalter zur Einstellung der richtigen Zeit.
Stunden-Switch - Durch Drücken dieser Taste gleichzeitig mit dem Schalter auf die richtige Stunde Einstellung zu erhalten.
Minute Switch - Durch Drücken dieser Taste gleichzeitig mit der Zeit den Schalter auf den richtigen Minuten.
Dynaalert (Wecker) - Depressing thr Schalter auf den ersten und dann über die Zeit eingestellt VERFAHREN (nicht in Betrieb) wird Ihr Wecker gestellt. Nach dem Alarm auslösen Schalter ist so um die Uhr funktioniert normal.
Alarm Switch - Mit diesem Schalter Ursache des Alarms zu einer vorgewählten Zeit ertönt. Release-Schalter, um den Alarm abzuschalten. Alarm wird auch gehen automatisch nach 1 Minute, wenn Sie nicht mit dem Schalter Freigabe wählen.
Radio einschalten - Drücken des Funkschalter wird das Radio dazu führen, dass wiederum auf der vorgewählten Zeit. Drücken Sie Schalter auf Radio auszuschalten.
Counter / Tine - Ist dieser Schalter bewirkt, dass der Empfänger Frequenz angezeigt, um in den Empfangsmodus und die Sendefrequenz im Sendebetrieb gefunden werden.
Auto Switch - Ist dieser Schalter bewirkt, dass die Zeit gefunden, um in den Empfangsmodus und die Sendefrequenz im Sendebetrieb gefunden werden.
Zeit-Schalter - Mit diesem Schalter Ursache der Zeit kontinuierlich angezeigt werden.
Tony
Apr 23, 2011 | Cobra Radio Communications
Habe einen Acer Veriton 7600 G der sich einer
Hallo,
Also wäre nett wenn du ihn saubermachen würdest. Viel zu viel staub. Es kann aber auch sein das sich dein Ventilator nicht mehr dreht, weil er total verstaubt ist oder ausgebrannt. Um dies zu testen, bitte den PC ausschaulten, öffnen dann den Ventilator mit dem finger drehen und sehen ob dies einfach geht. Wenn er sich nur sehr schwer dreht oder garnicht, dann muss er ausgewechselt werden.
Abschalten, ist einfach weil der Ventilator den CPU nicht genügent oder garnicht abkühlen kann.
Apr 18, 2010 | Acer Veriton 7600G PC Desktop
Psp makes buzzing noise and only makes sound when headphones are used
meine psp hat störungen weil ...wo ich gestern aufs sofa gesesen bin hab ich von der psp musik gehört und plötzlich wo ich auf steh mit der psp in der hand ist der sound aus und geht nicht mehr wen ich höre dan knakst es und raschelt und ich weis nicht warum? ich habe version 6.20
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
Hallo ich brauche euere hilfe seit 3 tagen komme
Das ist ein Problem mit der Facebook-Website. Der einzige Weg, es zu beheben ist, indem Sie die Support-Team und lassen Sie sie wissen, der das Problem gelöst. Wir hier bei Fixya müssen nicht die Mittel, um dieses Problem für Sie lösen. Danke.
Dec 07, 2009 | Facebook Social Network
Fritz!BOX fon WLAN 7170
DHCP und FritzBox gibt öfters Probleme.
Ich würde eher meine Drucker auf DHCP umstellen als den Rest der PCs und die Fritzbox.
Bei HP - Druckern kann man das via InternetExplorer ändern.
DHCP vergibt zwar die IP´s automatisch, aber nicht dauernd neu.
Erst wenn die maximale Anzahl an Geräten erreicht ist oder ein komplettes Reset gemacht wird.
In meinem Netzwerk laufen 5 Rechner und 3 Drucker, verbunden über einen SMC - Switch, alles über DHCP. Geht problemlos.
übrigens: das ist ein englischsprachiges Forum, da kann eine Frage auf Deutsch länger bis zur Beantwortung brauchen :)
Aug 18, 2008 | AVM Computers & Internet
MSI MS-6734-10 (-6734-010) Motherboard Logo
681 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
