Question about Sony Televison & Video
How to open locked dvp ns518p dvd player - Sony Televison & Video
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
SOURCE: DVP-NS305 DVD Player
Your system is in child lock mode. I had this exact problem this week. You need to put the system into standby mode and then press return, then enter then on/off and it will be unlocked.
Posted on Sep 04, 2007
ANDREIONELUV
  • 29 Answers
SOURCE: philips dvp 5992 Disk drive wont open
HELLO MY NAME IS ANDREI
I THINK YOU MIGHT OF LOCK THE DISC. BY DOING THIS YOU BLOCK THE PLAYBACK OF THE CURRENT DISC. SUBSEQUENT ACESS TO A LOCKED DISC REQUIRES A SIX DIGIT PASSWORD THE DEFAULT PASSWORD IS 136900. THIS WILL UNLOCK THE DISC LOCK FEATURE. MAKE SURE YOU GO YO SETUP AND CHOOSE UNLOCK DISC LOCK PERMANENTLY OR IT WILL KEEP DOING IT EVERYTIME YOU PLAY THE SAME DISC. HOPE THIS MIGHT OF SOLVED YOUR PROBLEM.
Posted on Jan 15, 2009
  • 10 Answers
SOURCE: SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
  1. In the setup menu there is a setting for Custom Picture Mode.
    Could someone have turned the color down?
    You can go to the setup menu and "Reset" the player to the factory settings.
  2. How is this connected to your TV?
    Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
    If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
    If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
    Are the cables in good condition?
    No breaks, loose connectors, they weren't smashed under a piece of furniture?
    Have you tried a different set of cables?
  3. Test the DVD player on another TV.
    Does the same thing happen?
    Did you "Reset" the DVD player?
    Maybe the DVD player is bad?
  4. Find another DVD player and test it with your TV.
    Does it work OK, or is it black and white too?
    Maybe the connectors on the TV are bad?
    Is there a custom setting on the TV for that connection?
    On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
There are may possibilities, but these are some of the basic things to check.
Best wishes,
-Greg-
Posted on Sep 14, 2009
SOURCE: DVD player wont open says E:26:00 then shuts off
Solution #3 worked for me.
http://www.fixya.com/support/t127790-error_message_e_26_00
Posted on Oct 09, 2010
How to Unlock a Sony DVD player DVP SR320 which displays "LOCKED" when eject/open button is pressed?
Apr 22, 2012 | Televison & Video
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
The "L ch" message is
To cancel child lock in DVP-SR200P dvd player, press power button to turn unit Off (standby mode) then press Return, Enter and Power buttons on remote.
This will cancel child lock in dvd player.
Hope this info will help you.
Thanks.
Nov 03, 2010 | Sony DVP-SR200P DVD Player
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
SOny DVD Player DVP-NS50P Locked
press stand by and press return button and enter button and then press stand by button on ur remote control.the player will be unlocked
Dec 27, 2009 | Sony DVP-NS50P DVD Player
Trey locked
There is a lock on this on the remote or end the menu system I do not remeber witch. You can unlock this software if not you need to unlock it hardware witch gets a little tedious.
May 24, 2009 | Sony DVP-NS700P DVD Player
Sony CD/DVD Player DVP-NS501P: It says LOCKED when I try to eject
What you have to do is unplug it and plug it back in it resets the dvd player
Nov 15, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
SONY DVP NS5OP is LOCKED
probably you locked it mistakenly, what you should do leave the player in standby, press RETURN, ENTER and then POWER buttom again. watch a nice movies.
Feb 07, 2008 | Sony DVP-NS50P DVD Player
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
