Question about Refrigerators
SHARP REF SJ-21UGL POWER SAVING REF?
TWO DOOR REF, 6.9 CU.FT...I WANT TO KNOW IF THESE MODEL IS A POWER SAVER OR ENERGY SAVER?
  • 42 Answers
SOURCE: Our refigerator is not cooling .
Hello Laura,
If you look at the rear wall inside the freezer compartment down low and find a bunch of frost on that wall, you have an automatic defrost system failure. The most likely part that has failed is the defrost thermostat. It is located on the top of the freezer coil, clipped onto a piece of tubing. It will have 2 wires coming out of it and it is about the diameter of a quarter and about 3/4" tall. To test this part you would need a test meter and enough skill to check if the contacts are closed when the thermostat is frozen withing the specifications stated on the thermostat. I believe yours would close at 25 degrees F and opens at 47 degrees F. Part # 5303918214
I hope this helps you. supertechks
Posted on Mar 28, 2008
  • 111 Answers
SOURCE: leaking everywhere
sounds like the door was sprung and is not sealing properly,check around door carefully for air leaks,miss handling causes this, did the same guys deliver the last one, just a thought
Posted on Jan 31, 2010
  • 51 Answers
SOURCE: Trying to locate parts list for Woods 7.4 cu ft Upright Freezer
http://www.tradebit.com/filesharing.php/search/0/wc+wood/0/1
Posted on Sep 16, 2010
heatman101
  • 43501 Answers
SOURCE: What is the cu. ft. of model 52552100, serial
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Posted on Oct 07, 2010
  • 5062 Answers
SOURCE: how do change the
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
Posted on Feb 25, 2011
I bought sj-5501 Sharp fridge . Yesterday I have no lighting on the front panel display of the refrigerator The refrigerator works right What could be the reason ? Thanks,
You can try one of these;
1. Hold down "Energy Saving" and "Lighting" buttons simultaneously for 10 seconds (or top left & right buttons). Display panel returns immediately
2. press the Freezer and Ref buttons at the same time for 8 secs and Bam!!!! Bac 2 normal!
3. pressed the power freeze and vacation buttons for about 3 secs and it worked
4. I held the top left and top right soft touch buttons on the screen itself (which I think is the power save and the lighting buttons) and held for about 8 - 10 secs and it reset
Hope it helps. Its in the combination of two buttons pressed simultaneously. Try your luck.
May 16, 2016 | Refrigerators
Hye..recently i just notice my sharp plasmacluster model sj-pt491m-bk the chiller is not working. Not cold as normal. The above freezer working normally. Plz advise
Open Freezer Door Press Door Switch and checked Freezer Fan is working or not.
If fan is working then problem in Ref compartment. If not working then replaced Fan.
In Ref Compartment checked all duct clod air is coming or not.
If not coming then Damper is defective.
Dec 25, 2015 | Sharp Refrigerators
I have a samsung Refigerator RF4287HABP that has an error code SE after a power failure. What should I do.
According to Samsung Customer Support SE stand for Sensor Error... after a power outage... so follow the same procedure as 1e (holding the save energy and lighting button for about 6 to 10 seconds.)
Jan 02, 2015 | Samsung RF4287HABP 28 cu. ft. 4-door...
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Oct 13, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Why is the red light on? on the touch screen next to energy saver
have you tried pushing the energy saver button to see if it goes off. I would think it is the indicator for the energy saver
Jul 26, 2014 | Samsung RF4267HAWP 28 cu.ft. French Door...
My sharp freezer model SJ-229S-SL , UPPER IS WELL BUT BOTTOM NO COLD
Checked Damper in Ref its working or not. You can checked open Ref door press Door Switch and hold your hand near chiller tray Duct
Dec 27, 2013 | Sharp Refrigerators
I have a RFG297ACRS (Canadian Model of AARS). Bought new and delivered yesterday. Waited 2 hours before plugging it in as directed by the delivery guys. Plugged in 24+ hours ago but until now it's still...
must be on demonstation mode, manual says the following: press ENERGY SAVER BUTTON AND FREEZER/HOLD 3 SEC FOR POWER FREEZER BUTTON simultaneously for 3 seconds until an alarm sound is heard.
Jan 05, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Samsung rfg297aa display for both the freezer and ref. temp.read 0f?
You frig is in Demo Mode. Hold your energy save anf freezer temp button for 3 seconds or until chimes and you should be good to go!!
Sep 15, 2010 | Samsung RFG297AA (285 cu ft) Bottom...
Front center panel where doors meet to close are very warm/hot to the touch. Is this normal for this refrigerator?
yes they have heaters in them to help reduce moisture on the ref you can ussually turn them off by turning the energy saver feature on but this may cause moisture to build up on the exterior part and the inside of th ref
Sep 06, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Which setting on an Energy Miser saves energy?
OFF is the Energy Saver mode.
To reduce moisture, there is a heater around the door seal that stays turned on, using energy. If you switch to ON, you use more energy.
It is confusing though.
Jan 17, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
