Question about Sylvania Smpk4230 Digital Media Player
Need a driver for smpk4230 - Sylvania Smpk4230 Digital Media Player
Ikbt-50 driver needed
You don't need a driver! This is a Bluetooth keyboard. What you need to do, is pair it with your Bluetooth device.
First, charge the keyboard. Enable Bluetooth on your device. Now, push the small black button marked "ID" on the back of the keyboard. The button needs to go in pretty far. This will generate the Bluetooth code needed to pair your Device. You need to enter the four digit numerical code generated by the keyboard. That's it! You are paired!
Oct 25, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
My Sylvania smpk4230 wont charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 24, 2012 | Sylvania Audio Players & Recorders
Sylvania Smpk4230 won't turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_14_2012_3_21_08_pm.jpg
May 13, 2012 | Televison & Video
How do i put music on my sylvania smpk4230
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_filesWhen you connect the MP3 player to yourcomputer with the supplied USB cable then computer detects the player as anexternal storage device or a Removable disk, you can then view the folder onyour MP3 player. Open the music folder and create a new folder on the playerexactly the same way you create a folder on your computer's hard drive. Toorganise your music, make a folder name with the name of the music album andplace the album's MP3 files in this folder, then copy the mp3 files from thecomputer into this folder.
You will then be able to select the music you want to play by the music albumfolder.To delete a file from your MP3 player, connect thesupplied USB cable to your player and then plug it into the USB port of yourcomputer.
Jan 22, 2012 | Audio Players & Recorders
My sylvania smpk4230 mp3 player froze and now it wont turn off or anything
Get like a tooth pick and stick it in the reset button at the top.
Sep 14, 2011 | Sylvania SMPK8858 MP3 Player
I have a Sylvania SMPK4230 (4 GB), and I'm wondering what the eBook does. And if I am able to read books like I think, how am I able to download them onto it?
The manual is available here SMPK4230 Manual
The instructions for the ebook capability are on page 16.
Ebooks in text format, that is files with a .txt suffix are mentioned as being supported.
You can copy .txt files onto the device just as you can copy music or video files.
The player will display print on the screen for reading when you access those files.
I personally download ebooks to my computer and copy the ones i want to read on the go to my media player.
Other ebook filetypes are.lit, .htm, epub, and .pdf among others, but there is no mention in the manual if these are supported.
There are ebook conversion programs that you can run on your computer to convert to a type you can use.
Jan 30, 2011 | Sylvania SMPK8858 MP3 Player
I need Webcam ucom driver
i need the driver fou ucom web cam
Oct 16, 2008 | Intel Easy PC Camera Webcam
Drivers
I loss the drivers of HP LaserJet 1020 printer. I need now. Please help me.
Jul 16, 2008 | HP LaserJet 1020 Printer
Sylvania Smpk4230 Digital Media Player Logo
57 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
