Question about E-Machines eMachines Desktop PC
I'm working on my mother-in-laws emachine. It turns on, but wont boot up past the bios screen. I have tried researching what the root cause is, but I can come up with is maybe a cd bootable disk.
  • Anonymous Jan 04, 2009
    My friend's emachine with Windows XP Home version doesn't want to boot up. Once it tries it just keeps rebooting itself, and won't go past the first screen.
  • atitforever May 11, 2010
    Does the Hard disk run? (listen for the sound), is there a permanent red light on the front?
    atitforever
    Problem Solver:
  • 11 Answers
If you think that you cant able to fix your problem yourself and need remote support by experts at cheap rates so contact us—
frankmartin90@gmail.com
Note:
1) Its a remote support so, the experts come in to your computer and fix your problem.
2) We solve only computer problems by remote support.
3) The other problem is not remotely supported but answered by experts so; feel free to ask any question on any problem.
4) Did not need to pay in advance pay when you get solution.
  SO WHY YOU ARE WAITING ASK YOUR QUESTION TODAY
Posted on Jan 03, 2009
Wont go to login screen on boot up
When booting, try hitting F10 or F12 to access the system BIOS. then go to boot device and make sure its booting from hard drive first
Feb 02, 2013 | eMachines EL1352G-01w (884483537679) PC...
Tried to reboot my emachine desktop to factory settings when it shut off during. Now when i turn on it wont go past startup page
You have to try again cause if the process was interrupted the installation was not completed .and thi si steh reason that it does not boot to windows ..So ..reinsert the disk ..and go back from thebegining ..If it does teh same ..make sure you read what s teh problem ..It may be something related with missing drivers if you have a sata hard disk ..In this case you may need to use a diskette with the drivers needed (raid ; achi ) and install them as 3rd party ..or simply go to bios and disable the raid or achi mode for the hdd bus..and let it run in compatible mode or native ...Install the operation system ..than all drivers including raid ..and after that go back to bios and let it run in raid mode..if you think this is how you want it to work ..
let me know what you've managed to do ..
Jan 09, 2012 | E-Machines eMachines Desktop PC
When i turn on the computer it goes to the windows loading screen and wont go past that, ive reset it, unplugged it , and it wont go past that screen The computer is a acer E2200 desktop and it runs on...
Have you tried booting into Safe Mode? You can do this by pressing/tapping the 'F8' key after the bios screen (Acer Screen) comes up. If it does you boot correctly then, you can try to restore the system to an earlier date using System Restore. That's located in the start menu/windows orb at All Programs->Accessories->System Tools->System Restore
Feb 28, 2011 | Acer Aspire M3641 Dual Core E2200 PC...
My mother-in-law's IBM Thinkpad will not boot. When she turns it on, there is just a lock icon at the top of the screen. It is a secondhand laptop, but it worked just fine for a few months. What could be...
Someone has got into the BIOS configuration and entered a Power On Password and when you enter the correct password you can then enter the BIOS to remove this password or allow the laptop to boot up into Windows.
This password is stored on an EEPROM chip and there are no backdoor passwords available.
The Power On Password is used to protect the laptop from unauthorized access.
Dec 13, 2009 | IBM Computers & Internet
Computer crashed, not sure how to recover it and what to use.
TRY BOOTING WHILE PUSHING F10 OR F11. MOST GATEWAY AND EMACHINES HAVE A RECOVERY PARTITION FOR A BACK TO FACTORY RECOVERY.
May 28, 2009 | Gateway GT5012 PC Desktop
PC wont start/boot
hello...i think you need to check all socket connection on the board and you need to check the memory or try to reset the Bios.or check the ATX power supply it is good or working..thank you
May 08, 2009 | eMachines D3415 PC Desktop
MY PC WONT COME ON THE SCREEN IS BLACK
The mother board has a battery if thats the one you took out you reset the bios, Try pressing the delete simutanuosanly after turning on the computer then in the bios goto boot device priority and select your hard drive press f10 which is the save and exit. Try turning on your pc again and see if it boots off the hard drive make sure you give the computer time to re-boot itself after you change the setting in the bios.
Apr 08, 2009 | eMachines T3604 PC Desktop
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
Emachines wont boot
Bad capacitor(s) on the motherboard can cause this problem, corrupted BIOS maybe... try flashing BIOS.
Probably the CPU if your not getting any error code beeps on startup.. NO Processor for the BIOS instructions thus no Beeps !
Nov 27, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
63 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
