Question about Sharp Refrigerators
Is sharp non-cfc refrigerator power saving?
IT DOESN'T WORK EFFICIENTLY...i plug in the ref for almost 20hours but the ice is not that hard..then the surface of the ref was getting hotter and hotter...what would i do to make it efficient and power saving? help pls?
    Sergeant:
    Champion:
  • Sharp Expert
  • 243 Answers
Checked any gas leaked from compressor.
Posted on Mar 03, 2015
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: i defrosted my refrigerator..after doing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 16, 2011
walesarumi
  • 6993 Answers
SOURCE: refrigerator doesn't get cold at
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover. 2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover. 3. Disconnect the defrost thermostat wiring connector. 4. Remove the defrost thermostat from the evaporator.
As for the ice maker, read the tip on this link. It was posted by me: http://www.fixya.com/support/r7602816-steps_when_ice_maker_not_making_ice
Keep me posted for more information and direction.
Good luck.
Posted on Aug 11, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have hss25gfpww refrigerator. I
The leading cause of both the ref and freezer side cooling but not too effectivly isa dirty/dusty condenser coil...pull the refrigerator out from the wall and clean all the dust from the coil on the right side behind the rear coil.
GENE
Posted on Sep 10, 2011
  • 107 Answers
SOURCE: hi i have refrigerator of
Check if the fan in the freezer is running. Also check for ice blockage in air channels between freezer and refrigerator section.
Posted on Sep 25, 2011
Kenmore side by side model 106.44109300 doesn't power up every time, freezer and refrigerator lights blink, unable to change refrigerator or freezer temperature settings, lock out light is off, quick...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | Kenmore Side by Side Refrigerator
Fridge is not running. light does work. need schematic
NOTE: This
MORE TRICKS:
Leo Ponder
imufo2
Leo Ponder
Sep 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a domentic rm2652 rv refrigerator/freezer. the unit was working but now it won't work. The power light doesn't come on and it won't work on gas or electric.
NOTE: This
MORE TRICKS:
Leo Ponder
imufo2
Leo Ponder
Sep 23, 2011 | Dometic RM2652 Refrigerator
My whirlpool shows CF-curcuit failure.what that means
NOTE: This
MORE TRICKS:
Leo Ponder
imufo2
Leo Ponder
Sep 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Roper Refrigerator is not staying cold enough. In the freezer ice cubes will start to melt and then refreeze and condensation collects on stuff in the fridge, then everything cools off again...?...
NOTE: This
MORE TRICKS:
Leo Ponder
imufo2
Leo Ponder
Sep 22, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
I have an RV with a Dometic frig It will not cool down
NOTE: This
MORE TRICKS:
Leo Ponder
imufo2
Leo Ponder
Sep 22, 2011 | Dometic RM2193 Compact Refrigerator With...
Ice melt, water coming from ice tray onto the floor. After clean, found ice maker doesn't work at all. Please help.
Clogged drain line! Look in the bottom of the refrigerator for a drain hole or check in side your rear panel on the back Ref.
Sep 16, 2011 | Refrigerators
I have a KitchenAid Superba side by side made in 1998. We haven't used the ice maker in many years as it has been a "second" refrigerator without water supply. Now it's hooked up to water...
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
I'm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 28, 2011 | KitchenAid Refrigerators
The ice maker doesn't work & water drips down from the freezer to underneath the vegetable crispers. It is not the plug. Is there a turn off valve on the ice maker line so that no more water can...
NOTE: This
Leo Ponder
imufo2
Aug 09, 2011 | Whirlpool ET1MHKXM Top Freezer...
Ice-maker stopped working
Pour Water manually in Ice maker and wait for ejection. If it ejects then the water mixer valve
underneath the rear of the Ref is defective. If it doesn't eject then the icemaker itself is the fault.
Leo Ponder
imufo2
Jul 16, 2011 | KitchenAid Refrigerators
Refrigerators Logo
53 people viewed this question
Top Sharp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
