Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washing machine not switching on no lights coming in control panel
My washing machine is awz 990, no lights coming while switching on may be board gone, fuse of the service wire intact and current coming upto board, when i get a new board or throw this one in waste bin and buy new one
    Sergeant:
  • Whirlpool Expert
  • 243 Answers
Check that all the many wire connector plugs are seated correctly
on the board
Posted on Sep 05, 2016
  • 249 Answers
SOURCE: wash cycle will not start
the door interlock is faulty, hit the door handle area with the palm of your hand, make sure machine is turned off 5 mins before hand. Replace door lock IRE bye.PS it should open when you hit it bye again. remember the palm of your hand
Posted on Nov 24, 2007
aborcass
  • 2651 Answers
SOURCE: Changing a Whirlpool Washing Machine Control Panel
youll be able to uninstall all the knobs(screws behind the knobs), then take off the switches from the panel without really needing to take wires off the individual switch.the timer is a tricky knob to remove (there is directions printed in the palstic housing of the timer back itself explaining how to release the kob
Posted on Nov 20, 2008
onthejob5130
  • 640 Answers
SOURCE: I HAVE A WHIRLPOOL AWZ
servicematter.com,,,or right here on fixya.com...always shop around..onthejob
Posted on Jan 24, 2009
localwonder
  • 6784 Answers
SOURCE: whirlpool calypso no control panel lights or
Yes, this particular brand is notorious for this. the actual control boards were reconfigured to no avail.
Unfortunately, you will need to replace this failed control once more.
Posted on Jun 19, 2009
  • 39 Answers
SOURCE: I have a CE error on the Calypso washer. I remove
First off is it under waranty and second you will need to find out what Ce stands for.Ask a repair shop and they might let you know what the code stands for.
No need changing something that don't need to be.
If it's not under waranty I would say yes you could replace it.The wires are usually all different and no way to get them hooked up wrong.(Note Just Make Sure It's Unlugged.)
Posted on Oct 22, 2009
AWZ 475/S IT WONT TURN ON. THE BLUE 'END' LIGHT JUST REMAINS ON AND THE MACHINE WONT START. WHAT MUST I DO?
I DON'T KNOW. PLEASE TRY UNPLUGGING THE MACHINE FOR A FEW MINUTES THEN PLUG IT IN. THIS MAY GIVE YOUR MACHINE A RESET.. IF YOU CAN THEN DO A SHORT WASH TO SEE IF ALL IS
WELL.
I RECENTY WORKED ON AN OLDER MACHINE THAT HAS A MECHANICAL TIMER CONTROL THAT YOU TURN TO THE RIGHT TO MAKE CHOICES. THE WASHER WAS STOPPING IN MID WASH FOR NO APPARENT REASON. IT WAS A MAYTAG-NEPTUNE.
INTUITION SAID THE CONTROL HAD DIRTY PHYSICAL CONNECTIONS IN THE TIMER
I SPUN [ TWISTED ] THE TIMER CONTROL KNOB
ABOUT 25 REVOLUTIONS TO THE RIGHT. ALL IS WELL NOW.
Feb 09, 2018 | Washing Machines
Washing machine will not spin at the rinse cycle
front loader belt driven ?
even a clutch system
if water is still in the bowl it wont spin
could be a water pump or water level issue
or timer or control board
Jul 04, 2016 | Kenmore Washing Machines
Cannot remove rubber door/drum seal on whirlpool 1000 awz 410
I also need to replace the door seal on my Whirlpool AWZ 410 washer. Does anybody have detailed instructions of how to do this for this particular machine model (not generic instructions) & know if it is necessary to remove the front panel on this machine in order to remove the existing seal please?
Feb 23, 2013 | Washing Machines
Whirlpool awz 412 not spinning
You will need to replace the motor control board. It is malfunctioning on the high speed control.
Apr 24, 2012 | Whirlpool AWZ412 Front Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
Kernmore elite He3t
Well there is one of two control boards that is malfunctioning, most common is the Machine (or Main) control board, there is also a display pc board in the control panel, but i have had few problems with that control. Unfortunately the main board is $300.
Sep 04, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
