Question about Toshiba Satellite L850-BT2N22 Customizable Notebook Laptop
How to enable touchpad on Toshiba Satellite L850?
  • Toshiba Master
  • 27,725 Answers
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Posted on Nov 01, 2012
Jumper location for toshiba satellite L850
From memory, there is no jumper. Look for bare solder pads near the bios battery... usually marked 'RST' or 'FRST' or similar. There will be a few pairs of pads grouped, you only need to short out the RST ones (a pair) Its a bit of a juggling act, but short them out during the process of applying power to the laptop. so... short out, maintain the short, plug in power, power up laptop, maintaining short for about 3 seconds..... remove power, restart.
Nov 27, 2014 | Toshiba Satellite L855-S5240 15.6" Laptop...
Toshiba satellite L850 bios password reset
Under the RAM there is a jumper "B500" Remove the battery. power source and RAM. Link B500 for one minute.
Feb 27, 2014 | Toshiba Satellite L850-ST2NX1 : Laptop...
Toshiba laptop touchpad not working
Most likely your problem is that the touchpad was disabled. Enabling/disabling could be done in two ways:
1. press Fn and F9
2. in control panel, mouse, you will find the option regarding enabling/disabling touchpad (in some machines called internal pointing device)
Aug 07, 2011 | Toshiba Satellite L655-S5101 Laptop
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Toshiba M35 S320 touch control buttons have stopped working. How do I fix it?
The TouchPad is enabled by default. To change the enable/ disable TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click the Mouse icon. 4 Click the TouchPAD ON/OFF tab. The TouchPAD ON/OFF tab view window appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply. 7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window. 9 Close the Control Panel window.
However, still if it does not work, you need to download drivers for touchpad.Here is link to download the drivers for touchpad. Under the "All categories link choose Touchpad"
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=556040&rpn=PSM30U&modelFilter=M35-S320&selCategory=3&selFamily=1073768663
Mar 27, 2010 | Toshiba Satellite M35-S320 Notebook
How do i get touchpad on toshiba laptop to work?
Control panel (classic View). Click the mouse icon. Under TAB TouchPad ON/OFF make sure TouchPad is set to Enable.
Under advanced tab, click Advanced features setting you will find additional configurations for the touchpad.
Hope it helps.
Sep 26, 2009 | Toshiba Satellite M115-S1061 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Hi! My touchpad mouse has stopped working in my toshiba satellite L305-S5875 notebook please help
While holding the "FN" key, press the "F9" key and that should re enable your touchpad.
Apr 19, 2009 | Toshiba Satellite L305D-S5874 Laptop
Synaptics touchpad not working
Have you looked at the Device Manager to see if there's a problem with the touchpad?
Start -> Control Panel -> System -> click on Hardware tab -> click on Device Manager button. Do you see anything that indicates a problem with the touchpad?
Also, you might want to check the BIOS to see that the touchpad is still enabled. I doubt that this setting would have changed, but it's worth checking. When you boot the computer you should see a message that says something like: "To enter setup press XXX" where XXX is the delete key or some other key. Once you're in the BIOS poke around to see if you can find the settings for the Touchpad. Different manufacturers use different BIOS' so I cannot tell you exactly where to look.
Good luck.
Dec 19, 2007 | Toshiba Satellite A20 Satellite A25 Series...
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Feb 09, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Satellite L850-BT2N22 Customizable Notebook Laptop Logo
4,283 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
