Question about Toshiba 51H93 51" Rear Projection HDTV
Toshiba Wide-Screen ,front projection, HD, LCD Colour adjustment to rid of rainbow in picture
Can a manuel be downloaded or is there a better description of how to adjust picture?
  • 113 Answers
SOURCE: hd picture too wide
If you are using a cable box you need to look on your cable remote for HD ZOOM or you can try the # sign on the remote. This should change your screen size and get you taken care of.
Posted on Feb 09, 2008
  • 74 Answers
SOURCE: toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Posted on Mar 24, 2008
egadgetguy
  • 258 Answers
SOURCE: picture off center on Toshiba 46" rear projection HDTV
On some models there is a picture position setting. One for horizontal and one for vertical. Don't mess with convergence, that probably won't help. Older models use knobs; new ones use the menu. Either way, you are looking for position adjustment.
Older sets, for each there should be size, hold, and position. Same for menus but it may have a picture that looks like one square offset on top of another.
Good luck. and if you need more help, please state the model #
Ken
Posted on Jan 01, 2009
SD Tech
  • 14553 Answers
SOURCE: Picture image is unsettled when
LINES or noise from left to right etc. This is a classic problem in a lot of these sets--that this clears up after a while is also typical---the period will gradually get longer and longer for it to become normal.
This set uses a Hyper board for all signal from all inputs---about two dozen tiny surface mounted filter capacitors on that board---they dry out and lose value---flat caps will when hot attempt to regain some of the value they should have.
Board is no longer available from Toshiba, only way to fix is remove one in set and send out for repair to someone like PTS Electronics.
I have seen experts try to replace the tiny caps--usually several are off value or open---cheaper to send board out. Last one I saw cost was about 200 for rebuild, keep in mind same problem will happen again in 5-8 years.
Let me know if you have questions and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 21, 2010
SOURCE: I have a 55 in Toshiba Cinema Series HD the colors
I have a Cinama Series HD Toshiba and it has a Problem with the picture theres red letters behind the white , it like the colors are stretched, theres red eye above the real eyes and same with the teeth area, what could be the problem?
Posted on Mar 07, 2011
How do i get rid of a little rainbow on my tv
has a magnet been close to your screen cuz this will do that.
Sep 30, 2012 | Toshiba Televison & Video
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Mar 25, 2010 | Toshiba 57H81 57" Rear Projection...
I am using ColorStream for my HD inputs, the top and bottom of every HD input is cropped. how do i adjust in colorstream mode?
There should be a wide/screen size/ format button on the TV remote that allows you to make those adjustments.
Nov 11, 2009 | Toshiba 57H81 57" Rear Projection...
Screen was pushed in, takin covering/surround off and fixed screen, replaced covering/surround but colour not right, can see rainbow effect on pitcure. is there a certain way screen must go to transform...
If this tv has a feature called magic focus or perfect focus which is a button inside door that flips down on the front, then it has sensors on the inside of the screen. When it was pushed in, these were probably messed up and will cause a poor picture. It may be difficult to get those realigned. Magic focus will not work right until they are realigned.
Oct 23, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba tv - no picture
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 04, 2008 | Toshiba 57H81 57" Rear Projection...
Hd picture too wide
Feb 09, 2008 | Toshiba 57H84 57" Rear Projection...
Toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Jul 30, 2007 | Toshiba 46H83 46" Rear Projection...
Toshiba 51H93 51" Rear Projection HDTV Logo
20 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
