Hi i need a service manual for a electrolux wascator we106 washer if any one can help would be greatly appreciated
I AM IN GREAT NEED OF SERVICE MANUAL USER GUIDE ANY MANUALS AT ALL FOR THIS MACHINE WOULD BE OF GREAT HELP AS I HAVE HAD NO LUCK SO FAR ANYWARE
informatica
  • 1114 Answers
SOURCE: TIMEX T307S
You can download the manual from the link below: http://www.timexaudio.com/pdf/T307_IB56281_07.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 24, 2007
maklean
  • 1665 Answers
SOURCE: Service manual
http://www.user-manuals.com/advanced_search_result.php?keywords=teac+pld+2000&x=11&y=14
Posted on Apr 05, 2008
barkencoa
  • 3463 Answers
SOURCE: problem with hotpont ultima 1200
Go to www.hotpoint.co.uk and click on after sales, then click on download instructions, you will be given the option of choosing your particular model. and then you can view the instructions on screen, or print them off..
Hope this helps!!
Posted on Nov 19, 2008
  • 44 Answers
SOURCE: I need a service manual Electrolux 6500
I don't have a service manual but maybe I can give you some instructions that will make some sense. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. I hope this helps. Good Luck!!
Posted on Jan 03, 2009
  • 56 Answers
SOURCE: manul and user guide
try my parts department and double check your model number 877-262-1479
Posted on May 30, 2009
I have this wascator and I need the manual in English please. Thanks
http://www.laundrysystems.electrolux.no/Files/pdf_files2/ljungby/service%20manual/SM_438920151_W365_3300H_Clarus_EN.pdf
Feb 10, 2015 | Cell Phones
Tip
Great advice. I was able to replace my dog ears today with your help. Mine was a...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
  5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
  6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
  7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
  8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
  9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
  10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. If you get confused and require further assistance, please refer to my profile at http://www.fixya.com/users/jsrock516 and use the “Ask Me” feature. For excellent diagrams to assist in reassembly you can also refer to the searspartsdirect.com website. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Aug 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
I have this wascator. And I need the manual.
try here http://www.laundrysystems.electrolux.no/Files/pdf_files2/ljungby/service%20manual/SM_438920151_W365_3300H_Clarus_EN.pdf
Feb 10, 2015 | Washing Machines
I got a Kenmore 3.5 washer and it does not want to start up! It appears to be a setting problem All the lights to the far right a flashing.If you can be of any help please let me know! Thankyou
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%&&
Sep 15, 2010 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
New electrolux EWGD65HTS dryer posts fault code E71 following "install mode". gas and electric installed corrrectly.
if this unit is new do not try and fix yourself. if your break anything it will void your warrenty. call electrolux they have great service companys and if they can trouble shot it with you they will overnight the parts to your house and set up service for you. electrolux is a great company and will help you get your dryer fixxed as fast as they can
Jul 03, 2010 | Electrolux EIED55H Dryer
Whirlpool frontend washer smelly cloths...need
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(*&^%
Mar 19, 2010 | LG WM2688HWM TROMM SteamWasher
Kenmore TL washer doesn't spin at end of cycle, burn rubber smell
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*%^%%$$#
May 20, 2009 | Kenmore 24032\24036 Top Load Washer
Electrolux ewt 1016 leds are flashing random
It appears your controller/timer has failed in this instance.
Jan 19, 2009 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
