Question about Tefal Avant Sandwich and Waffle Maker Sandwich Maker
Tefal model 39221 waffel&griddle replacement cord who has it?
2 Suggested Answers
eugbug
  • 479 Answers
SOURCE: Looking for a replacement electrical cord (power
A lot of kitchen appliances use a removable power cord with a standard connector.
Try your local electrical store and they may be able to help you.
Posted on Feb 26, 2011
Mi plancha modelo G1490 no calienta, no prenden los lod diodos wool silk y linen coton y max.
follow this steps and fix it. God bless you
f the iron doesn't heat, make sure power is on to the outlet, check the electric cord , and check the thermostat and replace if necessary. If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Oct 27, 2013 | Tefal T-fal E9421364 Castiron Plancha...
Looking for a replacement electrical cord (power cord) for a 1988 Tefal Wafal Maker and Griddle. Any suggestions about where to go.
Feb 26, 2011 | Tefal Avant Sandwich and Waffle Maker...
Need power cord for ge electric griddle model #106733
www.powercord-manufacturers.com/kp-GE-Electric-Griddle-Model-106733-Power-Cord-10431.html
here is an active link that may help.
Nov 09, 2010 | GE Kitchen Appliances - Others
How do I season the griddle that came with my new gas stove?
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use: -Wash griddle in hot soapy water. Rinse and dry completely. -Apply a thin coat of vegetable oil to the entire surface (front and back of griddle). -Preheat your oven to 350*F. Place the griddle on the upper rack in your oven. -Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing. -The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle: Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process. DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use: -To prevent rusting, store in a dry place and keep uncovered. -After each use, clean with a stiff brush and hot water only. -Do not clean griddle in the dishwasher. -Dry immediately and apply a light coating of vegetable oil to griddle before storing.
Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
My Presto Griddle Model 07032 02 Series 0298 with Plug Model # 0690003 control E73717 gets so hot that even the counter top gets very hot along with cord and plug end. What do I do to fix this?
I WAS GIVEN A PRESTO GRIDDLE & THE LEGS MUST HAVE BEEN CRACKED IN SHIPPING; THE FIRST TIME I USED IT THE LEGS BROKE. I HAVE NEVER BEEN ABLE TO USE IT & WOULD REALLY USE IT A LOT IF NOT FOR THE LEGS. WHAT CAN WE DO ABOUT THIS.IT IS MODEL# 07032/ 21 INCH & THE DRIP TRAY HAS A PIECE MISSING OUT OF THE SIDE ,WHICH WILL MAKE IT LEAK IF I USE IT. WHAT IS MY SOLUTION?
Aug 04, 2010 | Presto 7032 Indoor Grill
Need replacement cord for WP's cafe collection reversable griddle
I need a D.G. King Way PO-0800 Plug for Model No. CCRG0030 ,
for Cafe Collection Reversible Grill and Griddle. Do you have one and how much is it?
Feb 28, 2010 | Wolfgang Puck Reversible Grill and Griddle
Plug in cord for Presto electric griddle model #7032
you can find them on amazon. take a look Amazon com Presto electric griddle parts (note: watch out on sellers rating) Hope this was helpful. regards
Mar 27, 2009 | Presto 07034 Electric Skillet
Presto griddle model 07034 power cord
Here is a web site that you can get the cord from.
http://www.pressurecooker-outlet.com/7034.htm
Good Luck And Please rate FixYa!
Dec 11, 2008 | Presto 07034 Electric Skillet
Electric cord for Wolfgang Puck griddle
I NEED A ELECTRIC CORD FOR WR APPLIANCE MODEL CCR G0020 12VAC 60HG 1800W----UL LISTED 6H14----E196854-----DC KING WAY PLUG PO 0800 PLUG
Mar 19, 2008 | Wolfgang Puck Kitchen Appliances - Others
NEED EXTENSION FOR TOASTMASTER COOL EDGE GRILL MODEL 896S
I'm assuming you mean the power cord. Most of these units use standard power cords. Take it to an appliance parts store to match it. If you can't find the cord you want, extension cords called heavy duty are available. Be sure that the power draw on the label on the cord equals or exceeds that of the unit. Some cords use 'amps'...some appliances use watts. To get amps from watts: take the wattage, divide by volts (typically 120) to get amps. A 1200 watt appliance uses 10 amps. Use the next highest rating.
Jan 01, 2008 | Kitchen Appliances - Others
Tefal Avant Sandwich and Waffle Maker Sandwich Maker Logo
60 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
