Question about Apple 21.5" iMac Desktop
What does this error code mean...4SNS/1/C0000008 TL0P==124
Replaced HDD with same manufacturer but larger capacity. Sensor cable fit perfect as original, but fans running fast. Did hardware test and came up with this error code...4SNS/1/C0000008 TL0P==124
  • 48 Answers
It's a temperature sensor error, usually the fans run at maximum rpm when this happens. The error indicates the LCD temp sensor is either reporting out of range data, is disconnected, or has failed. It is probably a damaged or disconnected sensor cable. A disconnected or missing sensor would simply force the fan(s) to run fast to protect the system.
Posted on Dec 07, 2013
  • Hugh Browton
    Hugh Browton Mar 31, 2015
    I've this error code after replacing both the temperature sensor AND the optical drive fan
3 Suggested Answers
fire sine
  • 382 Answers
SOURCE: Error code when running Apple Hardware Test
Its an issue with the hard drive in the lower slot. The volume may be corrupt of the drive could be physically damaged. Did you install the bottom drive? is it the drive with the OS installed?
What does SMART statues report in DISK UTILITY?
Hard Drive/Application/Utilities/Disk Utility3a047e2.png
Let me know.
Posted on Oct 28, 2007
  • 22 Answers
SOURCE: DVD write problem and hardware test error code
I hope this works for you it did for me when I updated all my firmware.
http://docs.info.apple.com/article.html?artnum=88275
Posted on Apr 16, 2008
What is error code E3
If you have a gen one (finger ice maker) it means the th3 sensor is open. You will want a trusted technician to tackle this issue.
Mar 04, 2015 | Frigidaire FGTC2349KS Gallery Series 22.6...
Does anyone know97 Honda Odyssey with code P1361 Tdc?
P-Power Train
1-Manufacturer Specified Code (Honda)
3-Ignition System, Misfire
6-Component or Sub-System Section
1-Component or Sub-System Section
P1361 is: Intermittent Interruption In TDC 1 Sensor Circuit.
Check out the TDC sensor, connector 124 (grey and on the distributor) check power and grounds. It's missing a signal from the TDC sensor in the distributor and causing a misfire.
Oct 24, 2014 | 1997 Honda Odyssey
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Apple hard test error 4sns/1/40000000:tp0p-131.000
This error code is from the PSU sensor. Verify that the single pin connector on the top edge of the power supply is present and securely plugged in. If damaged replace the DC PSU cable. Causes the CPU fan to run at full speed.
May 01, 2012 | Apple Computers & Internet
Code 124
Throttle position sensor circuit is intermittent or faulty throttle positon sensor.Reset the computer after replacing any sensor.
Jan 12, 2012 | 2006 Honda Civic
My Precor 9.31 made a loud "click" sound and turned off while I was walking on it. Error 22. What does this mean?
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started.
1. Drive motor brushes are bad or the lower PCA is bad.
Apr 15, 2010 | Precor 9.31 Treadmill
About SCSI
Replace the hard drive with a drive that is the same type and the same size, or larger. It will rebuild itself.
By same type I mean that the connector on the back of the drive and the speed of the drive interface must be the same. If the new drive spins at a different rate it will not create a problem, except that if it is slower it will make read/writes slower. If it is larger it will only use part of its capacity, matching the capacity of the other drives.
Note that if you were to replace all drives with larger drives (one at a time) the capacity of the entire array would be the same as the original. If you want a larger array it must be built from the start with that larger capacity.
Take out the bad drive. If you can get the exact same drive, do it, otherwise look it up on the manufacturers web site to find out size and type.
While there are a few possible RAID configurations that you could be using on that server, the chances are overwhelming that it is RAID level 5 that you are using. This RAID level is tolerant of a single drive failure. If you lose another drive before your new drive rebuilds your data will be lost. Hopefully you have a backup.
RAID 5 stripes the data and the parity data across all available drives and when a drive fails, the missing data is rebuilt on the fly from the parity data. When a replacement drive is installed the parity data is used to rebuild the data that belongs on that drive. The advantages of RAID 5 are fault tolerance (of a single drive) and speed because each drive only has to provide or write its portion of the total data being accessed or written.
May 26, 2009 | Acer Altos G710 Server
Can Asus P4VP-MX motherboard supports 120GB HDD SATA?
Sky's the limit, or budget. You should not have any problem upgrading
to a larger HD. Have a good day.
Feb 10, 2009 | ASUS P4VP-MX Motherboard
My windows xp cant boot propery it is restarting itself.
-Try to boot the system to windows xp cd,then run windows repair.
-repairing windows make take up to 1-2 hours depending what capacity of hdd you have but you may need to complete the repair.If repair failed to complete.
-contact manufacturer and have them diagnose the entire system. and chck for the system warranty and look if there any error code if the error code lead to replacing the hdd, then request to replace the hdd.
Oct 11, 2008 | Gateway Computers & Internet
Jan 13, 2008 | Apple Power Mac G5 Desktop
Apple 21.5" iMac Desktop Logo
1,696 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
