Question about Fujitsu LifeBook P1610 Notebook
Fujistsu lifebook brightness - Fujitsu LifeBook P1610 Notebook
2 Suggested Answers
  • 199 Answers
SOURCE: What is the ac polarity of a fujistsu lifebook
In household and commercial electronics 110-125 AC has no polarity unless there is a safety ground, in which case the green safety is connected to to the white wire via earth ground. Black is "hot" meaning if you touch it you will feel a shock because your body connects the circuit to ground. A laptop operates on DC power delivered from an AC-DC converter usually around 20 Volts dc and 3.5 Amps, and charges the battery as well. Polarity of your computer is positive tip meaning the fat part of the plug going into the jack is ground, or negative, and the center is positive. I hope this helps.
Posted on Jul 05, 2009
Fujistsu AWY14LSAZ error 82
look on inside of door(s) for diagnostics or manual for the flash codes.need to know what code diagnostic is or give details to what it is doing or not doing, problem with a/c or heat ?
Jan 24, 2014 | Heating & Cooling
I have an IMac with a Fujistsu S1300. I upgraded the harddrive and now the scansnap application does not work. I have tried to re install the scansnap but it always gives the same message" General Error...
There might be a software package that you need to install that you can probably get from the Fujistsu main site. You'll need the drivers for the scanner. I think i've located the correct ones here:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
You'll want to download the proper package. The top one should include the S1300, just make sure you're downloading the correct one. Once downloaded, install, and it should properly function.
Dec 13, 2013 | Fujitsu ScanSnap Manager
My Fujitsu lifebook T902 keeps changing the screen brightness levels for no apparent reason.
I would think that if the virtual level controls are not changing, either the power socket/supply, back light or invertor has an issue.
Dec 01, 2013 | Fujitsu LifeBook Computers & Internet
Fujitsu lifebook A series brightness control not working.
Right Click Power icon in Tray Notification Area, click on Power Options, The power option you chose, to the right, open Change Plan Settings, Adjust Plan Brightness.
Nov 22, 2012 | Computers & Internet
My lifebook has a black screen but windows running
It could be the monitor or graphics card or CCL are done. Or maybe a simple small switch that shuts-down the light when the lid is closed. I repaired a HP that the switch had "stuck" in the closed position, you could see the screen in the bright sunlight and see the windows OS. The background light,CCL in older machines, was not lit. I once had to access the rear of the monitor, in a laptop, to re-insert a loose ribbon cable that had jared loose causing the screen to go dark.
Oct 29, 2012 | Fujitsu Lifebook P8010 Notebook
How do you adjust the light and darkness of the screen
Pres and hold down Fn. While holding down the Fn key, press F8 to increase brightness or F9 to decrease brightness. If its not working, that means that your hotkey driver is not installed in the computer. With that you need to download the driver from the driver support website below:
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS
Hope this will help.
Jun 15, 2010 | Fujitsu LifeBook N3010 Notebook
How is it piossible to change the brightness of the diplay
There is an Fn. button located in the bottom left of your keyboard.
Press this along with either the F4 or F5 buttons to decrease/increase the brightness.
Oct 09, 2009 | Fujitsu Siemens LifeBook S-6120D Notebook
Fujistsu T4215 no POST, numlock blinks
You need to send it to Memphis, Tn for a factory reset, call the Fujitsu 800 number on there web site and have your serial number handy.
Don't disassemble a Fujitsu!! Ever!
They automatically lockup as a security precaution, aren't you glad you saved some money?
Oct 07, 2009 | Fujitsu LifeBook T4215 Tablet PC
What is the ac polarity of a fujistsu lifebook c2330?
Jul 05, 2009 | Fujitsu LifeBook C2330 Notebook
Fujitsu LifeBook P1610 Notebook Logo
21 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
