Question about Canon PIXMA MP210 Photo All-In-One Printer
I have problems scanning pictures.
Every time I try to scan something on my printer, it always says "Copying... Scan after it is complete. Code: 2,112,0." It never did that before and all of the sudden it says it now. A few days before it said that, it also told me that I needed to maintain my printer, but I have no idea how I'm supposed to do that. I would really appreciate it if you helped. Thanks!
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Lexmark x9350 will not copy or scan.
Great job on trying to do it both ways, scanning and copying. Try to refresh the printer by uplugging the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure other end of the power cord is plugged in straight to the power outlet in the wall, bypass any surge device or power strips. Plugged the power adapter back in the printer after 30 seconds. It should automatically turn on. If not, press the power button. Try scanning and copying again. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the hardware problem in the printer. Hope I can assist you more on this.
Jun 29, 2010 | Lexmark X9350 All-In-One InkJet Printer
Trying to scan, but keep getting error code 2,162,0 My scanner printer - my Canon 4370 won't scan. Printing and copying is working fine.
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!
Sep 08, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Cannot scan wirelessly from HP Photosmart 4580 wirelessly
I reinstalled the printer software and reconnected the wireless connection and it now works well. I read somewhere that registry cleaner software may remove HP files that are required so this time after the registry cleaner scan, I unchecked any HP entry or printer entry and the scanner is still working, however, only from the pc to the printer, I still cannot scan using the buttons on the printer.
Jun 06, 2009 | HP Photosmart C4580 All-in-One InkJet...
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Apr 23, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
MP 160 Cannon Printer Won't Scan
try checking if you have completely installed all the drivers for your printer. scanning and copying dont usually needs drivers because you can do that even without a computer. but scanning requires your scanner to be read by your pc. try checking for the scanner driver from the cd that came from your printer.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scan does not work.
hi!!
try to re-install the driver PIXMA MP210 Photo All-In-One Printer
Nov 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Trying to scan a picture to my computer
Scarlet, I have a mid 2007 iMac and find that the MX310 does not always behave with OS X Leopard. To scan via software. Turn on the printer. Select SCAN from the printer. Press either PRINT (Black or Color) buttons on the printer. A fax - scan icon will appear in the dock and a window will open allowing you to fax. Now comes the problem. Often it will not scan the first time, I almost always get the message ¨SCAN FAILED¨ the first time I scan. Just click scan again without touching the printer will usually work. Sometimes I have to play with the settings on the left side of the scan window, switching between duplex and simplex or B & W and color and back. Usually this frees up what ever is stuck. Once it works, it works! After the scan, quit the scan and save to either a PDF or one of the photo file types (JPEG, TIFF, etc.) The results wind up in the PICTURES folder under the name of the printer and then the current date.
Jim
Jun 14, 2008 | Canon PIXMA MX310 All-In-One Printer
Scanning problem
Possibly there is a key that locks the engine that moves the scanner lamp, and that key may be locking the engine, and when the scanner try to move the lamp, the locked engine overloads the circuit, and turn off the device. Search for that key, and unlock this, (if it´s really locked).
Apr 18, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Epson Stylus scan 2500
Upgrade your Mac OS to 10.4 ($129US), download the latest printer software (free) from Epson and you will find these problems solved.
Feb 24, 2007 | Epson Stylus Scan 2500 InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
117 people viewed this question
old marine
old marine
