Question about Sony SDM-HS73P 17" LCD Monitor
Blinking screen on Sony SDM-HS73 17
So, lately my monitor has been blinking uncontrollably. The problem started about 6 months ago, and about after 10 minutes of blinking the monitor would finally work. Now, over the past week it continues to blink and I am unable to use my computer. I took the back cover off to look at the board, and it appears a few of the capacitors may have burnt out. C1, C23, and C25 appear burnt (black, brown in color) and the rest are all blue. I'm assuming this is the problem? If so, are they easily replaced? Where can I find them? I'd prefer not to order them online, I'd rather find them at a local store if possible. If I do replace them, is it as easy as pulling the bad ones out and sticking the new ones in? Or is there something special that needs to be done. Thoughts and/or suggestions would be appreciated. Thanks in advance....
  • Deuce4off Oct 27, 2012
    I said they were burnt capacitors, that may not be the exact term for them. I did a quick search on Google and it said something about capacitors, so that's what I called them. Either way, they definitely are located at C1, C23, and C25.
  • Deuce4off Nov 03, 2012
    Someone want to give me an answer or is this forum worthless?
  • 150 Answers
SOURCE: Dead KDf 60xbr950; 6 blinking red lights. I spent hours on research & would like 2nd opinions, please.
Not the board, there is a thermal fuse under the lamp housing that has opened up, you need to order an upgrade thermal fuse link that will mount to the Lightengine side of the lamp housing, the clips are there, there is no sensor there.
Posted on Jul 17, 2007
MikeNJ1964
  • 398 Answers
SOURCE: Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Posted on Sep 30, 2007
MikeMaierTV
  • 206 Answers
SOURCE: KP-53HS10 Red blinking light/screen turns on and off
When a Sony does what you explain it usually only needs it's screen controls adjusted. This would be the first thing before replacing parts or any other trouble shooting, To do this you have to remove the speaker grill, there usually are two screws down low that are covered by plastic covers, once these are out the bottom pulls forward and slightly down. Then there will be another cover, remove that. Now you should see the inside of the TV. Near the front there will be a control ruffly the size of a pack of cigarettes and have six controls on it, Three are for focus and three for screens, Next find a video source that has no input, this simply means change to a input that has no signal, and gives you a black screen. Next simply turn the screens clockwise till a faint glow and retrace lines appear, then turn it back down till the color just disappears. Do this to all three, then you can re-glue them with fingernail polish if you want to.
Thats the simple way to set the levels on the CRT's, Sony's have a circuit that mutes the video until all the voltages are within a certain range, if the voltages are too far off it will give you the five blink error code, now if does not fix the problem there are other problems, This can be any thing from a weak CRT to a capacitor failing. And on a final note it is best to let the set run for at least 20 minute before doing this adjustment to let the voltages stabilize, and it is best to check it after another twenty minute to make sure it stayed
Posted on Mar 03, 2008
AvioriX
  • 689 Answers
SOURCE: Sony Grand WEGA KDF-60XBR950 60 3 RED BLINKING LIGHTS
It seems there is power supply related issue like overheating, I suggest you to try again after keep the TV unplugged about 30 minutes.
Posted on Jul 01, 2008
welcomejee
  • 10594 Answers
SOURCE: SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
Posted on May 18, 2009
Screen white and power button blinking
Try another monitor if it works ok then the other monitor needs replaceing if it still does the same then you need replace the graphics card.
Terry
Apr 02, 2014 | Sony SDM-HS75P/S 17" LCD Monitor
I have a 2008 ZX6R and once and a while the low oil red light starts blinking and then stops. seams like a little more often lately. the bike is not low on oil either. i did an oil change about 6 months...
Hi Kx450f, youmay have a faulty oil pressure switch which should be easy to replace and for more information about your question please visit the website below. Good luck and have a nice day. 2008 Kawasaki Motorcycle Service Repair Workshop Manuals
Jul 24, 2011 | kawasaki ZX-6R Ninja Motorcycles
Blinking Screen
The fault could be a faulty inverter board which supplies high voltage to the CCFL lamp or the CCFL lamp is faulty.
You maybe be able to get service, parts and DIY info from LCD Parts. Click on this link to their WEB site :-
www.lcdparts.net
These other sites may also be useful.
http://www.yallstore.com
http://www.shope2.com/
http://cgi.ebay.co.uk/I565-LCD-Screen-Display-replacement-for-HTC-S740-S743_W0QQitemZ390065288445QQcmdZViewItemQQptZUK_Computing_LaptopAccessories_RL?hash=item5ad1b3f4fd&_trksid=p3286.c0.m14
Nov 16, 2009 | Sony SDM-HS73 17" Flat Panel LCD Monitor
I bought a SONY GRAND WEGA LCD Projection HD-TV about 2 years ago i rarely use it about 6 to 7 times,i turned it on lately and the screen shows no picture ,power light blinks yellow for a few seconds then...
Its possible that one of your fans has failed, and or it could be the lamp itself. Sony television will not power on if a fan is faulty. Open the back of unit and look at all fans to make sure they are running, if so then replace your lamp.
Oct 12, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blinking screen
that is ur monitor problem. if it is in warranty period ask for replacement. else approach a hardware servicing shop nearby ur place.
Dec 29, 2008 | Computers & Internet
Black screen blinking green light
You have a bad backlight fluorescent bulb.
Dec 28, 2008 | KDS 17S 17" Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Sony SDM-HS75 tft lcd monitor
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Mar 02, 2008 | Sony SDM-HS75 17" LCD Monitor
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Medion's Dark screen
I see you've downloaded the video card driver, but how about the driver for the monitor? It's a long long shot, but I shall refer you to http://www.monitor-drivers.com/ It's worth a shot, afterall I hate seeing parts thrown in the basement. Sadly your problem sounds far worse than a driver problem (which is probably plug and play anyway). It sounds to me like a monitor on it's last leg. Severe problems that happen gradually like you described point to something beginning to fail. First it takes forever to start up, then later you have to turn it off and on again real fast to get it to initialize, then finally it just craps out.
Dec 07, 2006 | Medion M3 Director 5100 PC Desktop
Sony SDM-HS73P 17" LCD Monitor Logo
67 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
