Question about Sanyo DP46849 46 in. HDTV
Sanyo dp46849 right side is darker
The right half of the TV is darker sometimes. It's like it's on a delay and looks really bad. If I turn on the TV and let it sit for a while without any input, then turn it to whatever I'm watching it will work for hours without any problem. Is this the this is a T-conn board going bad? I have quite a bit of electronic repair experience and feel comfortable replacing it. I could not find a free service manual download so I figured this would be a good start. Thank you in advance for your help.
  • Sanyo Master
  • 1,212 Answers
The problem is in the power supply! You must replace the capacitors next to Connection 2 (CN2 is the location). Replace C615 16 volts at 1000Mf,C621 16 volts at 1000Mf, C605 25 volts at 470Mf. C632 is fine, leave it, as is. The 605 capacitor (25 volts at 470mf). Looks good, tests good, replace anyway! Now with this complete, resolder all of the transformers (Large and small) pins you can find. Resolder inverter connections CN4 and CN5. Resolder any and all heat sinks (these hold transistors and mosfets). This will correct the dark shadows you see on TV. Thanks for asking, Matt of Martins TV.
Posted on Oct 21, 2015
  • Sanyo Master
  • 8,617 Answers
Es it sounds like a Tcon but be careful ordering one because Sanyo had about 9 different versions of that model number all using different boards. You can get the correct one and free repair assistance from www.tvrepairworld.com
Posted on Oct 27, 2012
  • big_creepy_a
    big_creepy_a Oct 28, 2012
    Is there a way to test the Tcon board? I have a DMM. If I could get the info needed, I could replace the single faulty component. I'm comfortable with desoldering and soldering single parts. I just need to know what all my values should be.
  • Sonny Berry
    Sonny Berry Oct 28, 2012
    Unfortunately you would need some specialized equipment such as a scope.
SOURCE: Top half of screen is darker than bottom half
The problem is most likley the TV backlight - it is very unlikley to be the graphics card or video input or any other circuitry within the TV.
Also, the problem can be manifested by flashing or flickering of one or both halves of the screen, and sometimes it is a left/right split rather than a top/bottom split, depending on where the lights are positioned. Before failure, you sometimes hear a very high frequency buzz for a few weeks before it fails - the frequency can't be heard by most adults as it ranges from 15kHz-25kHz, but children\animals can usually hear it.
Generally you will need to replace the backlight tube or the invertor that drives it. Generally you can identify the backlights as thin glass tubes buried deep within the panel itself usually with one wire going to each end of them - they are very fragile. The invertor is connected to the backlight tube and looks like a circuit board, often containing a high voltage warning. Usually there are two or four conductors connecting the invertor to the tubes, which can be identified as thicker individual wires as opposed to the flat ribbon wire used for data for the actual image displayed on the screen.
On some screens you may be able to unplug\swap one or both tubes to identify if it's the tube or inverter.
Posted on May 03, 2009
SOURCE: Flicker
I had the same problem with the flicker. Mine was a Flicker followed by a greenish line through the screen. It got worse then after 2 months the tv stoped working the power didnt come on at all. I Im taking it to bget fixed. The guy said it has somthing to do with a burnt out switch in the unit.
Posted on Oct 20, 2007
  • 4 Answers
SOURCE: Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Posted on Jul 17, 2008
SOURCE: Magnavox 47MF437B/37 No Picture Green LED Good Sound All Inputs
I have No Solution but I am so glad that I found this board saves me lots of trouble. I have the same model with the very same problem..I found this site about a class action suit against the company. If this is a True Statement, it appears that there is No Solution for this problem. Our set is a little over two years old. Lots of money for something that last no time.
P.Scarboro
NC
Posted on Aug 12, 2010
  • 131 Answers
SOURCE: Our sanyo lcd tv is a couple of years old and
Hello; I am John at J. D. Electronics, Poland Maine. This problem is caused by a defective LCD panel. This part is very expensive! Aprox $ 1000.00 from Sanyo and less than $400.00 from Encompass Parts Inc.
Posted on Oct 09, 2010
Sanyo dp46849 no power
It is probably the power supply in you tv
it is close to the power inlet of the tv
look for capacitor s that are bold on top that means they are blown out
on one side there is a line with a - on it make pictures of it so you know with way to putt a new one back in it must be the same value microforat voltage schould be the same or higher
Jan 04, 2015 | Sanyo DP46849 46 in. HDTV
Vertical half screen gets darker
There's a board in the middle of the set ( back taken off) near the bottom of the screen. It has 2 flat ribbon cables that go to the screen. It is under a metal heat sink. That's the board that's causing the problem. www.shopjimmy.com has the board for a very reasonable price. Takes about 15 minutes to change.
Jan 24, 2014 | Sanyo DP46849 46 in. HDTV
Turn on my tv and it goes right back off
tried to disconnect all the output connectors from the power supply board, then make a voltage checking if output voltage is available. if no output dc voltages or drop you have bad power supply board.
Sep 03, 2012 | Sanyo DP46849 46 in. HDTV
Panasonic 37 inch lcd tv
Check its back light CCFL lam of that side, which look darker. Replace it.
Jul 15, 2012 | Panasonic Viera TC-37LZ85 LCD TV
My sanyo flat screen is fading on the right side but after awhile in clears up
Most of these sets use two boards that drive (each) one half of the screen---a problem can be a bad board or cable or plug connections and can escalate as time goes on.
Jun 16, 2012 | Sanyo DP46849 46 in. HDTV
Dp46849 Screen goes black after 10-15 minutes
This info was given to me by a HAM Radio friend that repairs TV's For a Living.
Disassemble TV, clean all boards from dust, unplug/replug all connectors,
most are really small, be careful, try TV again. Out Same Model TV started off the same, RIGHT bottom of screen/shadow when TV was on for awhile, since then has got worst, like 2 shadow boxes showed up, now upon startup, TV is screen is covered w/vertical lines, shut off the TV once or twice and works fine until next startup. If the above does not fix TV, look at the top of TV from Back Panel Off, Top-Center is a board called T-Con board, replace it. All the info for this board replacement is on the Bar-Code Laabel and Board itself, ie; T370HW02 VC CNTRL BD, 37T04-COG, FX-5546T03C22 (orC21)-964-0000NMP-00629-03 this board is Mgr By AU Optronics. GoTo For Parts/Pricing, they have 180 warranty on parts, aprox $45.00 for T-Con . http://www.shopjimmy.com/auo-55-46t03-c22-t-con-board.htm. He stated It IS Very Rare That The LCD Screen Itself Would Be The Problem. Right now I have Our Sanyo DP46849 apart
laying down on a bed, had to remove Base Pedestal to remove back cover,
There is a smaller cover, 2 screws u can remove to gain access to the turner board and power supply, there are 2 more boards hidden, before u remove back cover from front panel, untape wire leads from back of LCD Screen and unsnap the 2 torrid coils, black plastic things wires going through, these torrid/ferrit coils are mounted on a snap-in base, w/very small screwdriver they will unsnap from plastic base in 4 corners, if the base breaks from panel frame, just hot reglue back in place when are repairs are final. The 2 panels will seperate eaisly, if not you have some maore screws left to remove. Our TV was little dusty inside on the power supply board and alot of dust collected on some big transistors, 3 lead/legs, I'am hoping this caused the power problem @ start-up, going to clean all bard then reconnect all leads/cable, ect and retry, If no work will replace the T-Con board. Hope This Help's All
Dec 05, 2011 | Sanyo DP46849 46 in. HDTV
How do I fix a A black screen on the left side of
Hello; I do a lot of Sanyo repairs and have seen this problem several times. The left side may be black always or sometimes. In either case the LCD panel is bad. the part from Sanyo was last $1000.00. There seems to be some refirbs or knockoffs for $400. Time for a new set. John
Jul 08, 2011 | Sanyo DP46849 46 in. HDTV
Our sanyo lcd tv is a couple of years old and recently when the tv is on for the first couple of hours the screen will flicker and get progressivly darker from the center of the screen to the left....
Oct 09, 2010 | Sanyo DP46849 46 in. HDTV
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Sanyo DP46849 46 in. HDTV Logo
399 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
