Question about Refrigerators
Ic maker in sub zero 700 series makes ice but it melts into a solid block
Ice maker in bottom freezer draw
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model complete number listed on the unit?
Posted on Oct 28, 2012
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
SOURCE: Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Posted on Aug 22, 2008
SOURCE: sub zero freezer too warm
I believe the freezer has to get down to 7 degrees or lower for icemaker to harvest. Clean your condenser and blow it out. If that doe not fix it you will need service for sealed system
Posted on Oct 08, 2008
hbsurfdawg
  • 95 Answers
SOURCE: Ice Maker won't work
If your trying to save a service call you have your work cut out for you. The ice maker is a unit that sits by itself attached to the wall or part of the freezer wall.
There are many reasons why you do not get ice and I will list them.
1- Temp of freezer got too cold and has frozen the pipe that feeds the water to fill the icemaker.
check to see if the icemaker has any ice in the area that fills and makes the cubes.
If the pipe is clogged, very gently put a small tipped screw driver in the fill hose that sites over the ice making row in the ice maker. Be careful you do not push your screwdriver out the back of the refer.
Check to see the freezer temp is not too cold and is freezing that pipe. 0-3 degrees F is good.
2.- check to make sure your water feeding the fridge is on. There is an on off valve to allow the water to feed the icemaker when it needs to fill. This could be bad. there are reset proceedures for the fridge, but unplugging the entire frige for 1 minute and plugging it back in you can listen for the the valve to come on and see if it fills the ice maker resevoir.
3. If it fills and freezes the ice resevoir, then the sensor in the ice tray does not sense the frozen ice and will not cycle and kick cubes. At this point, unless you are super tech, you will need to replace the entire icemaker unit.
Hope this helps.
Posted on Mar 21, 2009
SOURCE: GE ice maker, solid ice in ice maker
ice clumps up in the ice bucket
Posted on Jul 24, 2009
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
Sub zero bottom freezer stuck and will not open
ice maker could have flooded over or the drain for defrost water is blocked and water is leaking into freezer.you have to shut down the freezer until you can get the door open parcially and then melt out the rest with a hair dryer,also shut off the water to the fridge in case it's from the ice maker and then find out where the water is coming from,if it's on the left side it will be from the ice maker,if it's on the right side it's the drain,if it's the drain you can buy a heater kit,a little tricky to install,you have to snake a piece of fishing line down through the tube to snake the heater into the drain and then wire it in so the heater will keep any ice freezing in the drain again,it comes with directions part number 4202160.you might want to call in a tech for this unless you're handy fixing things,but first find out if it's the drain or the ice maker
Mar 11, 2012 | Sub-Zero Bottom Freezer Refrigerator
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Subzero freezer with ice maker. Ice melts and refreezes, into blocks of ice. What could be causing this?
Good day,
In most cases it is the water valve that feeds water to the ice maker well. The valve is energized by the ice maker to fill for 7 seconds and then shut off promptly.
The valve will many times dribble water into the well after shut off, causing an overflow problem.
The fix is a new water valve kit.
The only other possibility is the freezer temperature going above freezing from time to time, but is a rare problem.
Mar 27, 2010 | Sub-Zero Bottom Freezer Refrigerator
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
    Clean the Ice Machine
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
    Reassemble the Ice Maker
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • Jul 20, 2009 | Refrigerators
    Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
    Refrigerators Logo
    61 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
