Monitor not working
Actually i was browsing the net and that while browsing, the monitor began to flicker and then it closed. So please tell me what i have to do and that what is the problem
  • 673 Answers
May be due to irregular voltage supply. The monitor could have shorted out. If you have warranty go for a replacement.
Posted on Oct 27, 2012
  • Sundararajan RS Nov 25, 2012
    Thanks i have sorted out
Problem with setting refresh rate.
Most LCD manufacturer recommend 60Hz, all the LCD monitors (close to 100, 2 monitors per work station) at my office are set to native resolution and @60Hz, LCD refresh rate does not work the same as the old style CRT. You can tell by using the digital camera to see if the screen is flickering or not, point the camera at the CRT monitor and you will see the screen will be rolling but not on hte LCD screen. Try this monitor with other PC.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 13, 2010 | Samsung 943NW Monitor
Monitor dims and flickers. doesnt get hot. the cables and outlet are all fine also. works but the flicker is annoying makes a weird sound on startup. no other refresh rates to choose from.
Dim and flicker problems are a sign of a back-light problem and it could be a faulty inverter board or a CCFL lamp.
For service, parts and DIY info check out LCD parts - Click on this link to their WEB site :-
www.lcdparts.net
Dec 19, 2009 | Acer 22" X223w LCD Monitor
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
Monitor keeps shutting off after a few seconds- hp dv4000notebook
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | HP Pavilion dv4000 Notebook
I have an Envision Monitor G221 WK which has suddenly started flickering badly. Any suggesions?
Try the auto adjust button first.
Does increasing or decreasing the brightness affect the amount of flickering ?
Flickering is usually a inverter board or a backlight bulb issue. You would have to take it apart to try to tell.
If you do take it apart and if you can send me pictures of the boards to bammbamm@ptd.net. I may be able to see the problems if it has typical issues.
fran
Aug 12, 2009 | Envision Computers & Internet
G Flatron L1515S 15" LCD
monitor display center line problem
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
Flickering picture
chech out some other devices near by to the monitor, they might cause interfearence and in a result your monitor flickers.
1. If there is nay CVT/UPS near your monitor put it away.
2. If you have any speaker without magenetic sealed it will cause flickering, keep it away from monitor.
Otherwise your monitor need to be get service. So please contact your manufacturer service centre.
Thanks
Iqbal
Mar 30, 2008 | Gateway FPD2275W LCD Monitor
Flickeing like a dying fluorescent light bulb
Actually this is a 'warning' signal from your lcd monitor. The problem is your lcd ccfl lamp are near to their life, need to change. The ccfl lamp like our home fluorescent lamp, when the lamp need to dead, the lamp will flickering first, after some time, will totally off(dead). So, this is a signal for you. Some lcd monitor, when their inverter board are using fairchild inverter ic(oz series), will easily shutdown your monitor when they detected some flickering on your screen (ccfl lamp). If you need more information on repair your lcd monitor please visit http://www.fastrepairguide.com . Thanks.
Jan 17, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Serious problem
Check WGA if it is correctlly put on and go to DISPLAY PROPERTIES - SETTINGS - ADVANCED -MONITOR
Oct 15, 2007 | LG Studioworks 700S 17" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
