Question about Kicker CompVR 05CVR84 Car Subwoofer
Can you tell me how to wire in my kicker px 100.2 amp
I am hooking it up to two 3.5 " infiniti speakers
  • 5 Answers
SOURCE: how do i wire 10' kicker cvr
dnt bridge the amp wiht a voice coil and keed the bass on the amp low and use vocal on the radio setting if you have the opintion
Posted on Dec 22, 2008
blueextc3221
  • 15935 Answers
SOURCE: how to wire a kicker 15 cvr
175W x 2 @ 2 ohms
350W x 1 @ 4 ohm
Your amplifier is not stable @ 2 ohm bridged. So you will have to wire them independantly on each channel.
+/- on sub to +/- on L channel
+/- on sub to +/- on R channel
Wiring the subwoofers in paallel will result in a 2 ohm load, which your amplifier is not rated to do. Doing so will cause heat buildup, and damage to the amplifier.
Posted on Dec 24, 2008
  • 26 Answers
SOURCE: how to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Posted on Jan 21, 2009
SOURCE: wiring
1st--on 1 sub put a wire connecting one red with white dot to the blk with white dot
2nd--do the same thing to the other sub !!do not wire a red/white to an all black
3rd--wire the full blk negetives to the amp, then same thing to the positive
Posted on Jun 22, 2009
robotek
  • 1512 Answers
SOURCE: can i hook up my sub if it's wired to a 2 ohm and my amp is 4 ohm
Hi martineztag
You should never connect a load of an impedance less than the min the amp is able to drive. This can have disastrous consequences that may easily result in failure of the amps output stages. You need to use a different configuration that does not overload the amp in this manner for safe operation.
regards robotek
Posted on Jan 19, 2010
Testimonial: "Thanks for the help should i just leave it 4ohms how do i wire it like that? "
I have 2 12" kicker solar baric squares L7 hooked up to a kicker cx 1200.1 amp as soon as I turn bass knob up it cuts out and amp goes into protective mode plus I have a 3 microfarad copasitor hooked up...
Sounds like your wiring is giving you the wrong impedance,Check crutch field advisors website for sub box construction and detailed wiring instructions.
Aug 22, 2014 | Car Audio & Video
How do i hook up my kicker comp dual voice coils
If you are wanting to run them bridges, I'm going to assume each voice coil is 4 ohms, then what you want to do is as follow
+1 -2
+3 -4
So on the diagram here, I know its silly, but you'll hook a wire from lead 3 to 1, that will bridge the positive side dow. Then you will hook a wire from lead 4 to lead 2. From lead 1 and 2, run your speaker wire to the terminals on the box. Now if you have a mono block amp, its not going to affect. If you have a 2 channel amp that is bridgeable, be careful. Some amps are not 1 ohm stable. Try and see. Good Luck.
May 02, 2010 | Kicker CVR15-4 Car Subwoofer
How do i wire two kicker l5's already in a box
if you have an amp then you hook it up normal... left side + from amp to + to speaker... - from amp to - to speaker, and same for other speaker....
if no amp then i'm not sure your radio will push that big of speakers, but you would hook them up normal.... hope this helps.....
Apr 14, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How to wire a 2400w amp to 3 12s subs
if the amp is a 2 channel, u could either bridge them all, or if you wanted to, you could hook 2 speakers to the two seperate channels, and then hook the other one to the negative on one channel and the possitive on the other. if this wasnt what you meant, just, try to tell me more about the amp... thanks
Dec 05, 2009 | Kicker CVR10 Car Subwoofer
How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Nov 23, 2009 | Kicker KX600.1 Car Audio Amplifier
What wires do i need to hook up 2 kicker solobaric s15l7 to a car
You will need the amp wires. Red Positive to battery, Black negative from amp ground to unpainted car body surface, and the blue remote wire that goes from amp to remote wire on back of cd deck.
Then you will need the rca cables from rear output of cd player to the amp.
Then just the positive and negative wire from speaker to amp. Use Speaker Positive wire to Amp Right Channel Positive
And speaker negative wire to amp Left Channel Legative wire.
That is it.
Nov 17, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2 10 kickers not playing. . .
Hello zqueliz,
It's possible that the sub is blown, but it may be something else. You did not specify how the subs are wired to the amp, how many channels on the amp, or whether or not the CVR's are in separate enclosures. These specifics will affect how you isolate the problem.
1) Check all of the wiring: RCA's from head unit to amp, speaker wiring from amp to sub. Make sure there are no breaks in the insulation and that the wire does not come in contact with another wire or metal parts on the vehicle.
2) Remove the nonworking sub from the enclosure and check the wiring from sub to terminal inside. While you have the sub out, check the "braided" wires going from the sub terminals to the cone.
3) Reverse the wiring from the amp to the subs to see if the problem moves to the right sub. That will tell you the problem is not in the sub.
4) If the left sub still fails with the amp channels flipped, you find no wiring defects, and you can't see any physical damage, test the sub voice coil with a multimeter. Set the meter to read "ohms" on the lowest scale. The actual reading should be a little less than the rated impedance. If the subs are 4 ohm, the meter should read about 2-3 ohms. If the meter reads "0" (pegs) or if it reads "infinity" (no reading at all), the sub voice coil is bad.
Hope this helps.
Apr 29, 2009 | Kicker CVR12 Car Subwoofer
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
General ?
they are dual 2 ohm all L7 are 2 voice coil per speaker so it is like 2 speakers not 1 the dual 2 ohm version is so you can use 2 speakers wired in series to get a 2 ohm load 2 ohms + 2 ohms = 4 ohms then parralel the 2 at the amp to cut it in half to get 2 ohms. I have full warranties on mine and i dont really sell alot of them any way I prefer the hifonics they sound better last alot longer and take way more power and put out 3 times as much sound. but i can check it out if you have the info.
Sep 17, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker CompVR 05CVR84 Car Subwoofer Logo
139 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
