Question about Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard
Mainboard error for install to win7 finalliting install
  • Foxconn Master
  • 3,606 Answers
Hello the mainboards homepage is here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000576
From here you can download a manual.
You need at least 1gb of ram to install windows
And min.1,6 ghz cpu.
Is the windows disk an original or a copy ???
If a copy it may have be burned too fast.
Burn it not more than 4x or it will skip some files
and not be able to finalise the installation
I could also be the dvd drive.
Try also to enter the bios and set it back to factory settings
remember to set up the boot option again.
You also need a sata harddrive.
An IDE drive is too slow.
First boot device dvd
And second the harddrive
Good luck
Posted on Oct 30, 2012
Gigabite Motherboard Audio Drivers Problem. Plz Help!
Hello try to find the mainboard here:
http://www.gigabyte.com/support-downloads/download-center.aspx?ck=2
By entering the mainboard number.
I suggest you try the vista sound driver, when windows 7 is not supported.
The vista driver sometimes work, on your windows system.
Good luck
Mar 27, 2013 | Computers & Internet
How can I install Windows 8 on my computer with M2N MX SE motherboard?
Hello try the asus homepage here:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2N-MX&p=1&s=24
The vista drivers should work, when you install windows 7 again.
The files has to be unziped, before you install the driver.
But that does not mean the drivers will work on win 8.
Here are the other models of the mainboard:
http://support.asus.com/Download/ModelList.aspx?SLanguage=en&keyword=M2N-MX&type=1
Consider to buy a new mainboard, that supports win 8.
A new mainboard cost around 100 dollars, and the cpu aswell.
You maybe have to buy new ram, because all new mainboards have ddr3 ram.
Good luck
Mar 11, 2013 | ASUS M2N-MX Motherboard
I'm using an intel chipset G41 express in my pc but I don't know why each time I change my system, my graphic memory(1G) used decrease , first 700mb with win7 64bit and now it's became 256
Hello download the right drivers here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41RQ
Or install a better graphic card, in the pci-e slot on the mainboard for better performance.
The onboard graphic, is useing the physical ram on the mainboard to operate.
Support for up to 8 GB of system memory.
Support for DDR2 800 or DDR2 667 MHz DIMMs
Good luck
Jan 24, 2013 | Intel Essential DG41RQ Desktop Motherboard...
P4vm800 motherboard driver for windows 7
Hello the driver site is here:
http://www.mercury-pc.com/downloads_list.php?productid=644
The drivers is probably only for xp but you can try to install win7 32bit
A 64 bit version will not run on this mainboard.
Consider to upgrade to a newer mainboard for better performance.
Good luck.
Sep 09, 2012 | Mercury P4VM800M7 Motherboard
I WANT THE IDENTIFICATION OF MOTHERBOARD MSI ms 7267 VER 4.2 945 GCM5 motherboard drivers
Hi, you can download drivers here:
http://www.msi.com/product/mb/945GCM5-F-V2.html#/?div=Driver&os=Win7%2032
But there is 5 models of your mainboard
the other one is here:
http://www.msi.com/service/search/?kw=945GCM5&type=product
Please select your operating system.
Select the driver and click on download.
Unzip the file before installation.
Make sure the drivers is for the right mainboard.
Sep 09, 2011 | Gigabyte GA-945GM-S2 (0818313003065)...
All the programes have been deleted from my pc windows 7 has been instaled but i have no sound drivers
1st hope that your mainboard is compatible with windows 7.
you need to go to the web site of your mainboard manufacturer for exp: msi, ati, asus, dell, hp, gigabyte, etc...
on the web site look for download drivers.
then you will need the model of the mainboard which is printed on the mainboard (in white text)
choose your OS, select sound or audio then click on the link to download the audio drivers.
If you dont see windows 7 for your mainboard, you can download it for Vista.
*if you dont see windows 7 or Vista, then you mainboard is not compatible with win7 and you will need to install windows XP
if its zip file, you will need to unzip it and run the setup file.
good luck.
May 28, 2011 | Computers & Internet
I got win7 installed on my desktop computer ( mother board msi k8mm-v V1.3) when i want to play games it gives me error message "windows media accelerator"
You need to install all the mainboard/chipset/graphic card drivers.
For the mainboard/chipset drivers, please check
http://www.msi.com/product/mb/K8MM-V.html#/?div=Driver
MSI is not prividing the Win7 drivers yet, but you can use the Vista drivers. Select the Vista version (32 bit or 64 bit) to be the same as yout Win7 type (32 or 64 bit)
Mar 01, 2011 | Computers & Internet
Hi i have motherboard 775i945gz intel and i want install win 7 but i can,t plz help me how i can download drivers for win 7?
Have to check mainboard for win7 compatability,a lot of older boards out there are not win7 compatable
Jan 14, 2011 | Asrock 775i945GZ Motherboard
Driver of soundmax onboard in Win7
Win7 is a recently dev version of windows. i don't think that the manufactures has begin writing the drivers for their products. see in the manufactures website if they have provided the drivers or else you cannot install the drivers. even if you some how install the drivers, the product cannot offer full efficiency.
Apr 22, 2009 | Computers & Internet
Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard Logo
43 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
