Question about Kenmore Elite 45986 Front Load Washer
The seal inside the washer is ripped - Kenmore Elite 45986 Front Load Washer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number listed on the washer?
Posted on Oct 27, 2012
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Washer ripping clothes
Check the drum baffles (the paddles inside the tub) to see if one is loose and also check the front tub seal for any tears.
Nov 05, 2012 | Washing Machines
Leaks from underneath
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Kenmore Elite Washing Machines
Leaking at each wash cycle
this sounds like the door seal has split,,,there not very pricy but a pain to fit,,,so here go's,,,
open the door,,look at the door seal pull it off the back of the door and you should fine a spring wire holding it there,,,undo this wire,,,now fold the seal into the washer over the inner drum,,,,there you will find the inner wire,,undo that wire and pull the seal out the washer door,,,,
to fit the new seal,,,turn the seal inside out and push it through the hole in the door then fit the inner wire on the inner drum first,,,unfold the seal and pull it through the door,,,now fit the outer wire,,,,not put the kettel on,,have a cup of tea take the pain killers for the head ache you just got,,, and think about how much money you just saved ????
now was it realy worth the trouble,,,i wonder? am i good or what?
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What cause the door seal to rip on maytag 9700
Lots of things can cause a door seal to rip. The most common is an object in the washer that doesn't belong there, such as a hairpin or a variety of other things. The door seal can also rip on it's own by being dry and grabbing on the glass when you shut the door.
Jun 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Seal on front loading washer ripped
yes it can...check the yellowpages for the part or repair.
Mar 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Clothes got tangled with rubber seal inside and ripped it. How do I fix/get a new seal?
This part is a problem on many front-loaders and never really goes away. The rubber seal is a replaceable part and should be supplied under warranty. There is no way to fix it.You should try very hard to get Sears to pick up the labor cost as well.
Mar 14, 2008 | Kenmore Elite 45986 Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
