Question about Dell Inspiron 5150 Notebook
Dell Inspiron 5150 Will not turn on......
Has worked perfectly for the last 4 years but suddenly....
- Will not turn on or even charge with the AC power adaptor plugged in.
- No lights, no nothing.
- I tried to remove the battery and plug in AC power, but nothing.
Any help out there?
  • 1 more comment
  • naus Jan 12, 2009
    I've got exactly the same problem, I'm still looking for solution. AC adapter is OK, but all LEDs are dead, FAN is dead, NTBK seems to be dead.
  • jamesleedawg Feb 13, 2009
    my problem is slightly differant as i can get 2 flashing led amber and green flashing only after i plug in the battery or a\c cord and then try to type on the keyboard!! any help greatley appreciated!
  • edi hulu May 07, 2009
    I have same problem
    Problem Solver:
  • 6 Answers
Had same problem, thought changing power jack would solve problem, but, it turns out the power supply is the problem,, works great with another dell ps
Posted on Apr 29, 2009
    Problem Solver:
  • 16 Answers
First off start with cheap, Replace the external powersupply, (the ac power cables and company)
Second, Replace the battery. However if it dosn't show the lights atall when it's plugged in it must not be the battery. Because even without the battery a light should come on saying the laptop is plugged in.
Finnaly what I think the problem probably consists of:
You most-likely need to get your computer repaired by someone, There's mostlikely a fault in the internal power supply. that charges the battery. I'm guessing maybe a little fuse or something popped and you need it replaced. But best get a professional to do it instead of someone who knows nothing.
No power battery flashes 4 orange
If it is orange or is blinking orange, the battery charge is low or expended. Remove the battery and re-install it. Plug in the AC adapter and connect it to an outlet. Turn on the computer.
When the battery status light blinks green and orange, the battery temperature is too hot for charging. Shut down the laptop, detach the AC adapter, and allow the laptop and battery to return to room temperature before attempting to charge the battery.
If the battery status light blinks orange rapidly, the battery itself may be defective.
Apr 08, 2012 | Dell Inspiron 5150 Notebook
Why it cannot run on ac and is not charging?
Please check your power adapter weather it is good or it is having a fault in it.
Jul 22, 2010 | Dell Vostro 1510 Laptop
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 5150 do not come on when the power button pressed
If you remove the battery and disconnect power cord, then hold power button for 20 seconds, then reconnect power cord but do not re-insert battery, and the unit powers on okay, the problem may be your battery. If there is still an intermittent problem, the power connector inside the unit may be loose and need re-soldering, or you could have a bad power supply.
May 17, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron 6400 Battery
your miracle,most laptop batteries have a life span of 4 years tops,but that if you take care of it,but most dont realize over charging kills the cells in your battery,and if you have it plugged up make sure you go into power settings and put it on ac/dc power settings.and if you have it away from home without power,put it on best battery settings,and let the power die all the way down before recharging,that will give it a full charge lasting longer.but as for your battery it might be time for a new one
Apr 14, 2009 | Dell Inspiron 6400 Notebook
Can't charge battery or run off AC
You may have a problem in the DC charge circuitry. These parts are located on the moatherboard directly and can't be bought separately and repaired. You must send your Dell to a specialised service to have it fixed by them. Sorry, I can't see no other way for this problem to be solved.
Jan 20, 2007 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 Notebook Logo
1,113 people viewed this question
Alun Cox
