Question about Honda Black Max 8750W Portable Generator Electric Start
Black max won't start after sitting for 18 months
I can't get it to start. I've put fuel cleaner in the tank. But the genni has been sitting for about 18 months before I put the fuel cleaner in.... Anything I can do?
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: EB5000 been sitting 6 months,
Hi and welcome to FixYa, I am Kelly
If the generator has sat for some time the fuel in the float bowl will turn into a varnish like substance (shellac). The residual fuel in the carb will have to be removed. You do this by removing the fuel solenoid (or bowl nut) which ever one youhave that secures the float bowl to the carb. Then take a screw driver and remove the main fuel orifice and remove the debris from the main fuel orifice. Clean the orifice with carb cleaner. DO NOT push anything into the hole! Also spray the brass tube that the main fuel jet screws into with carb cleaner. You should see carb cleaner being sprayed into the throat of the carb.
While the fuel float bowl is removed get a spray can lid and hold it under the carb float. Turn on the fuel selector and the fuel should completely fill the spray can lid in 8 - 10 seconds. If you do not have this amount of fuel flow you need to remove the main fuel line from the carb and re-check fuel flow. If the flow is good here then use carb cleaner in the float needle area to force any debris back out the fuel manufold connection that is now open because you removed the fuel line. If you still do not have fuel flow then check for debris in the fuel tank exit port, the fuel filter, the sediment bowl under the fuel shut off assembly.
Once again with the spray can lid under the float you should have fuel flow anytime the fuel selector is on and the float level is down. It should shut off fuel just as it reaches level. Any other result and the float and float needle will have to be removed, cleaned and inspected for debris.
Make sure to re-install the main fuel orifice in the treaded area that secures the float bowl in place and.re-connect the main fuel line to the fuel manifold / carb fuel inlet connection
If the engine has a fuel solenoid hook it up and and see of it is working as you turn the key / engine switch on and off before you reinstall the float bowl. You make have to hold the case of the solenoid against the engine to make a ground AWAY from any residual fuel for testing. I.e. don't burn up your generator.
Re-install the fuel float bowl and test the engine. It should now work just fine.
The above steps are successful most of the time on generatosr that have sat idle for an extended period. I have been working on generators large and small for over 40 years.
Thanks for choosing FixYa,
Kelly
Posted on Aug 26, 2011
Starts then dies - plastic carb
Sometimes, there is a waxy substance in the fuel tank and fuel lines that is put there by the manufacturer to prevent deterioration during storage. Machines may sit in a store for months / years before getting sold. I would get some fuel cleaner and flush the tank and fuel lines , then put some fresh fuel in the tank. I had to do this with a brand new whipper snipper. Had the same problem.
Feb 22, 2014 | Garden
My 95 Pathfinder has sat idle for a couple months and now it won't start.
letting a vehicle sit idle for months is not good !!! now you need to do some work, so get out your check book ! replace both air & fuel filters, replace spark plugs, plug wires, distributor cap & rotor, add fresh fuel & fuel injector cleaner to tank @ same time. why are you going from accessory to run, that doesn't make any sense, stop it, please ! now get to work, good luck !
Mar 04, 2013 | 1995 Nissan Pathfinder
I have a 87 Cutlass Ciera. 2.8 engine. I've had
Check this link out.Here's how to replace,if this doesn't work,take back for refund..
Dec 03, 2012 | Cars & Trucks
97cc baja doodle bug won't start
Assuming that the engine can be turned over with the starter, the most likely culprit is it's not getting enough fuel, especially if it's been sitting for 6 months or more. AT YOUR OWN RISK, remove the air duct after the air cleaner and pour a shot-glass full OR LESS of gas directly into the carburetor or throttle body. It should start and at least run briefly. If it does, then add at least 3-5 gallons to the fuel tank. If you've run out of gas, then adding just one gallon is not enough. Today's fuel-injection systems have pressurized fuel lines which need at least a gallon just to fill all the pumps and filters between the tank and the engine. Good Luck, TechJoel
Nov 04, 2012 | Cars & Trucks
1994 corvette bad Gas ?????
Try a little starting fluid in the intake (not too much, just enough to test). If it takes off for a second or so, may be water in gas. Ten months old? It should be alright, unless it's loaded with water.
May 31, 2012 | Chevrolet Corvette Cars & Trucks
Husky Chain Saw 4.1 Model 18 in Bar
Sounds like a gummed up carb. Inspect and clean carburetor. Particles of broken fuel line or resin of old gas maybe restricting fuel jets.
May 19, 2012 | Husqvarna Garden
2003 Chrysler town & country limited
First try and change the fuel filter. this also happened on a van i worked on. I cahnged the filter and it runs fine now.
Nov 16, 2011 | 2003 Chrysler Town & Country
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
Sitting for 18 months - put in new gas w stablizer - won't start
check fuel line bleed out the system cleal gas filter,check spark plug, the breather may be clog also check carb float may be stuck,good luck
Aug 12, 2011 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
Honda Black Max 8750W Portable Generator Electric Start Logo
691 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
