Question about Toshiba Satellite A205-S4617 Notebook
My toshiba satellite wont turn off, I shut is off and it said wimdows is shutting down then has stopped there the battery is very low but has not shut down
  • carolmoore14 Jan 08, 2009
    My toshiba would not turn off and froze in the middle of shutting
    down. I finally pressed the on button and held it down a couple secs
    and it shut down, and is working properly now. Thanks
    Novelist:
  • 176 Answers
Im assuming you have Windows XP so I would recommend getting the latest service pack for Windows XP. If this doesnt work go to Control Panel > Performance and Maintenance> Power Options. On Power Option Properties click on the "APM" tab and check box "Enable Advanced Power Management support" and the click "Apply" then Close.
Posted on Jan 03, 2009
My Toshiba Satellite U405 S2918 media lights stay on after I shut the power off ......
You might be on sleepmode. Make sure you shut it down properly. Removing the AC and battery will definitely turn it off, so as to be sure that you completely turned it off...
Hope this helps
Sep 06, 2010 | Toshiba Satellite U405-S2918 13.3-Inch...
Toshiba Satellite P205d S7479 shuts down suddenly when on battery. The battery is brand new.
Try to turn off the laptop
Remove cables and battery on the pc
Press and hold the power button for 5 seconds
reinsert battery and cables on the laptop
Turn on the laptop
Check if the PC still shuts down. If it is, try to connect the power cable without the battery. If it turns on, call your pc manufacturer to replace the battery....
Jun 21, 2010 | Toshiba Satellite A135-S4527 Notebook
My Toshiba Satellite PRo L300 won't shut down.
SIMPLY REMOVE BATTRY AND POWER SUPPLY
reconnect them
go to power options and check setting
"when i press power button"
select shutdown
May 05, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite lap shut down. charged and now will not turn on
Try on AC if works replace battery!!swampratt200!!AAAEEE!!!!
Jul 21, 2009 | Toshiba Satellite A60-S1561 Notebook
Toshiba Laptop turns itself back on after being shut down
go to toshiba's website
www.toshiba.com select your proper device and go to support put in your model number there have been some bios updates to resolve this issue. load all bios updates and you should eliminate this known issue.
good luck!
Ruben
Jul 18, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
I was shutting down my toshiba laptop, its now frozen.
If nothing else works remove the battery, leave it for 5 mins then replace it and it will start as normal. Yyou will get an error message usually saying it was not shut down correctly and it may do a system scan but unless there is a real problem with it that will restart it. Ive had to do that twice with mine in the last year.
Jun 15, 2009 | Toshiba Satellite A135-S4427 Notebook
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
When ac is plugged in the power light blink & notebook unresponsive
Sounds like your ac adapter (brick) is bad and not supplying correct voltage/amperage.
Apr 03, 2008 | Toshiba Satellite 2805-S603 Notebook
Laptop does not power on
Somtime low cmos battery could cause the pc not to start.
Take battery out /plug in your ac adapter
Shut down computer
hit f2, this will reset the bios.
Good Luck, Merry Christmas.
Dec 05, 2007 | Toshiba Satellite A135-S2246 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
