Question about Hotpoint HSS25GFP Side by Side Refrigerator
Fridge smell and taste makes you sick, very clean and no food in it
Omg i have a empty fridge that i cleaned all the seals, took everything out of fridge, ie: shelves and doors, and drawers, whatever, i even took those apart, cleaned with bleach, hot water, then a sanitizer, now it has baking soda and dry towels to try to soak up the smell but all i get is this really bad, makes me dry heave chemical smell, that came from an apartment where the tenants claim made them sick and food taste funny??????
  • christy trupiano Oct 27, 2012
    it was open for about 2 days, then i turned it back on and did the bakin soda and coffee ground thing, i cleaned with bleach, i used lemon pine sol i was so desperate but no use, the inside is so clean id eat off it for real, when u close the doors it still smells and we have it outside on porch and the smell lingers and travels inside house, its a chemical pungent smell ive never smelled b4 and believe me ive smelled all sorts of fridges
  • 673 Answers
Keep it open for a 4 or 5 hours... Then keep some cut lemon inside it.
Posted on Oct 27, 2012
miket756
  • 2702 Answers
SOURCE: we cleaned out fridge inside and out put in baking
its that darn coffee you put ith the baking soda causing the smell,wash it out again only this time only use the baking soda by itself,,, NO COFFEE!
and leave the door open for it to dry out, that should sort out the smell,,,,why did you use coffee with baking soda???? it causes it to smell bad?
Posted on Nov 14, 2009
shastalaker7
  • 1515 Answers
SOURCE: My fridge smells like hot vinegar, but I have
Hi, after reading you're problem, and the 1st solution, yes this pan sometimes can get really bad, but you said the fluid had no smell. That would not be the problem then. If you smell it when the fan comes on and it comes from under the unit, you will need help in pulling it out, to see what may be under there? On the back bottom, there should be a fiber panel that can be removed, unplug 1st, and there will be a small condenser coil and fan, also the compressor. Maybe there is something on this coil you can clean off. Be gentle with it as you can restrict the air flow if you mash down the coil fins. Smell and look very good and you should find the smell. Did it smell before the soda was spilled? I doubt if this is the problem. You will find it, just look behind it. It could also be a component failing. Please keep me informed, Sincerely,
Shastalaker7
Posted on Nov 26, 2009
  • 185 Answers
SOURCE: can't get the fishy smell out of fridge....used
I was watching tv the other day and they said if you want to get rid of awlful smelly smells use newspaper. Put newspaper in the frig and close the door. Let set for like two days and repeat. The newspaper will absorb the smell somehow because of the chemicals it has. It works great with pickle jars. no kidding.
Posted on Mar 23, 2010
MNTECH
  • 1543 Answers
SOURCE: Frig and freeze work fine!! But an ordor started and is staying!!
Most likely some raw meat juice leaked into a spot you can not see or get to. The defrost heater area and / or the defrost drain are the most likely suspects. If you can diss-assemble enough to get to these to clean, you stand a good chance of conquering your odor problem. Additionally, there is one odor absorber that has worked rather well for me, but I don't remember the exact name,.... but I'll post it in an additional comment tomorrow.
Posted on Jul 29, 2009
SOURCE: Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
Posted on May 04, 2009
What smell is coming from fridge
Remember that any thing you store in the freezer or fresh food compartments that are not in a sealed container will give off an odor and will also make the ice cubes taste funky..If you have not cleaned the interior in a while empty both sides and clean and then put an open box of baking soda in both sides.
Jan 05, 2015 | Refrigerators
Why does my refrigerator smell so bad?
PUT A BOX OF BAKING SODA IN REFRIGE AND 1 INTO FREEZER ALSO. BUT TAKE EVERYTHING OUT, MAKE SURE NOTHING SPILLED AND IS UNDER A DRAW ROTTING. IF ALL IS CLEAN INSIDE, PULL OUT REFRIDGE IN BOTTOM BACK IS AN EVAPORATOR PAN FOR CONDENSATION, SOMETIMES SOMETHING CRAWLS UP INSIDE GETS TRAPPED AND DIES.
YUCKY BUT VERY REAL
Jan 05, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
Why does the ice in my freezer taste and smell bad even though I changed the filter?
OLD PIPES NEED REPLACING,OR DID HOUSE WATER LINES SET A WHILE ,HOW LONG DID ICE MAKER NOT BE USED .CAN YOU REMOVE ICE MAKER AND CLEAN?. MOLD MAY OF ESTABLISHED OR RUST.TAKE WATER LINE OFF BACK THIS IS EASIEST. AND RUN 5 GALLONS OF WATER IN A BUCKET.TEST WITH A CLEAR GLASS WITH SOME FROM THE FLUSHING OUT WATER.IF IT DOES NOT CLEAR UP,HAS THE WATER COMPANY RAN TEST ON THEIR PRODUCT.THEIR MIXTURE OF FLUORIDE AND SUCH MAYBE FUNKY.DOES WATER LOOK CLEAN.GET CLEAR GLASS,FILL WITH ICE AFTER IT MELTS SEE IF THINGS AT ALL ARE FLOATING.DO SAME TEST AFTER YOU RUN 5 GALLONS OF WATER OUT OF THE LINE.ICE,MELT LOOK.HOW DOES WATER TASTE OUT OF DOOR IF THAT TYPE.IT CONFIRMS WATER LINE OR OUT OF FLUSHING WATER.IF IT TASTE OK FROM FLUSHING WATER THE SOURCE IS AS DESCRIBED IN THE FIX...
Jul 25, 2014 | Whirlpool Refrigerators
My Freezer-Fridge has a terrible smell, almost smells rotton or like something died. What would cause that smell?
It could be mold, clean with clorox and then wipe down with baking soda. Make sure you check your rubber rims/seals.
Dec 11, 2017 | Refrigerators
Chemical cleaner taste in water and ice from fridge door.
Run it as normal and keep flushing the water through. Place lemon wedges around the inside for the next week. If the problem persists you can buy a proprietory air conditioning system cleaner for cars that disperses inside the unit (make sure no food is left in while using) follow makers instructions. Clean with low pressure hot water spray before using again.
Apr 20, 2012 | Kenmore Refrigerators
Chemical smell in frig permeating food taste. Is it dangerous
First remove all the food and produce and thoroughly clean the fridge with disinfecting wipes, then put a couple of boxes of Arm And Hammer Baking soda in the fridge to absorb the odors. And no it is not dangerous in my opinion. I have smelled fridge odors that would gag a maget
Apr 25, 2017 | Refrigerators
The ice from the icemaker in my frigidaire has a chemical taste and smell. The refrigerator is old. I smell a bad smell when I open the freezer. What could be causing this problem? Model # for...
Some piece of rotten food stuck in the filter system.
Try replacing the air an water filters.
You can also make deep clean...
  1. Take all the things out of the fridge
  2. unplug it and clean everything inside
  3. Leave it like that with the doors opened for 3 days
  4. plug it back
Aug 24, 2011 | Refrigerators
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
444 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
