Question about Uniden GMR1235 Two Way Radio
Constant rx mode on Uniden two way radio - Uniden GMR1235 Two Way Radio
3 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Faulty Uniden UHO38SX-2, RX on all the time
Hello jbt3143, Here is a way to find the component that is causing the problem. open up the unit and then turn it on until the problem occurs. Then using freeze spray go in vertical lines from bottom to top of the circuit board until the problem clears. Not the section that causes the symptoms to go away and the by narrowing down the field you should come to one component, replace that component and the retest by turning the unit on and letting it heat up again. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 12, 2009
SOURCE: Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Posted on Apr 15, 2010
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
One of three Uniden GMR3740-3CK constantly recieves static that goes on and off. tried swapping batteries and did not work. rx display goes on. Very annoying. Other 2 radios are fine. Is there a setti
Well, it IS the squelch level. Most radios do not have an adjustment for this. Take the bad one back, you've done all the tests you can. Good job.
Jan 07, 2015 | Uniden Radio Communications
My uniden UH3O5sx is always stuck on receive (rx is always showing) can receive but not transmit
Set up your privacy tones or adjust the squelch level to stop the static and bring the handy out of receive mode. Some models have a busy channel lock out, that if it beleives it hears something it will not let you transmit over the other station.
Oct 04, 2014 | Uniden Radio Communications
Why does the uniden grant go into transmit mode when turned on
if this happens without a mic attached, it is common for the tx/rx switching transistor to fail
Aug 16, 2014 | Radio Communications
How to get rx off screen
This model has a "Monitor Mode" feature that allows you to listen for weak signals on the current channel at the press of a key.
1.) To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
2.) To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Jul 15, 2014 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Uniden uh064sx-2a constant rx
Press PTT and see its break receiving. Also change the Rx frequency or change the channel which not receiving, adjust the squelch level.
Dec 28, 2013 | Uniden GMR638-2CK (22 Channels) 2-Way...
Static noise rx
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
May 13, 2013 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
3040 ck
It's a Uniden model 3040 CK, is this correct, if so then the problem is due to someone or something causing a carrier frequency to be received by your unit, causing the Rx to stay open, the fact you can Tx and Rx the other station you're communicating with, indicates that the radio is working as it should, the problem is caused by external interference and not in your radio.
I hope this has answered your query.
Regards,
Peter
Nov 10, 2012 | Uniden Radio Communications
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Uniden GMR1235  Two Way Radio Logo
66 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
