Question about Car APS921 Remote Starter - Keyless Entry
Lights don't blink for remote start
I have a ELVATOE PROOE4BS remote starter. The running lights used to go on and stay on when the car was remotely started. Now, only the interior lights go on until the car is started. I must have pressed something to change the setting. It wouldn't be a big deal, but it makes it easier to tell if the car has started from the window. Any suggestions would be great.
    Sergeant:
  • 233 Answers
If you look at the unit (probably installed under the dashboard, on the drivers side) You can see the wires going into the unit... Follow the wires back and you will find that 2 of them have in-line blade style fuses, it sounds like the fuse in the parking light output wire has blown. if you find the fuse is blown, replace it and the parking lights should be on again when you remote start it.
Posted on Jan 03, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Remote starter not working elvatoe APS2K4SAW
Factory remote start or aftermarket ? What the hech is this elvatoe APS2K4SAW.If it isn't factory , get it out of there .
Feb 23, 2015 | 1997 Pontiac Sunfire
Elvatoe prooe4bs
I found this to be a battery problem in the key. Had a new battery fitted and problem fixed. The immobiliser works in very close proximity of the key and so it allows the car to start but there is not enough power in the battery to transmit to the receiver for the locks.
Jun 05, 2013 | Car APS921 Remote Starter - Keyless Entry
I have the PROOE4BS and my remote got water on it and the remote doesnt work but everytime i get into the car the alarm goes off and my car wont start. Is there any way i can bypass the alarm to start the...
Look under the dash for a small button or toggle switch. Put the key in the ignition, turn the ignition on, and press the button or flip the switch. That will put the alarm in valet mode to get you by until you can get a replacement remote. Reverse the process after you've replaced the remote.
Jul 06, 2011 | Car APS921 Remote Starter - Keyless Entry
Need progamming instructions for this remote. AUDIOVOX PURSUIT PROOE4BS ELEVATE Car Alarm Remote
http://www.google.com/url?sa=t&source=web&cd=3&sqi=2&ved=0CCcQFjAC&url=http%3A%2F%2Fwww.voxxsupport.com%2Fimages%2FUser%2520Manuals%2520-%2520FAQ's%2FPROOE4B.pdf&rct=j&q=prooe4bs%20manual&ei=WNIdTYymB82Ynwex-ty4Dg&usg=AFQjCNFYcmC74Al8MalM5ZCCThRzuRZEBQ&cad=rja
i hope that helps
Dec 31, 2010 | Computers & Internet
I just bought a car that came with two Pursuit PROOE4BS remote I can only get the remote starter to work but after the car starts2c if I enter and depress the brake2c the car will turn off Also I can27t...
if you enter the car after you used remote starter,dont depress your brake.you need to put your key(insert) into your igniton barrel
and turn it in to ON possition(dont crank the starter) now you can depress your brake to cancel the remote start.and your door lock and trunk maybe the installer didnt connect the wiring from remote starter to your car...
Feb 09, 2010 | 2004 Lexus ES 330
REMOTE STARTER NOT WORKING COMPLETELY
Here is page 2 of the owners manual, Hope it helps.
This will not start the vehicle if any one of the following situations exists;
The vehicle's hood lid is opened.
The gear shift selector is not in Park.
The brake pedal is depressed.
The safety control switch is in the Off position.
1. To start the vehicle, press and release the transmitter button two times within 2
seconds. The vehicle will start and remain running for the pre-programmed 5,10,15,20 minute run cycle. As a visual indication, the parking lights will flash or remain on depending on the setting by your installation center.
2. When you arrive at the vehicle, turn the ignition key to the ON position (not the spring loaded start position), then step on the brake pedal to disengage the remote starter. The
vehicle will continue to run, but now on it's own power.
NOTE: The engine will stop running before the pre-programmed run cycle has expired if you perform any one of the following functions;
-Press and the button on the keychain transmitter two times within 2 seconds.
-Depress the brake pedal.
-Open the vehicle's hood
-Place the unit in the safety control disabled mode.
PRLED SAFETY CONTROL SWITCH
The Push-Button LED control switch allows you to temporarily disable the remote starting function of the system. This recommended whenever the vehicle is being serviced. To place the system in the service mode:
1) With the system disarmed/unlocked, and the ignition switch off Press and Hold the PRLED on.
2) Turn the ignition switch on, off, on, off, on, off.
3) The LED begins to flash two short flashes followed by one long flashes and continues this pattern until returned to normal mode of operation. This puts the unit into the R/S Override mode indicating that the remote start is in the service mode and will not start from RF or any other input Posse or otherwise.
To Exit R/S Override Mode
1) With the system disarmed, Press and Hold the PRLED on.
3) The LED turns off indicating that the R/S unit is fully functional one again
Dec 18, 2008 | Car APS921 Remote Starter - Keyless Entry
Car APS921 Remote Starter - Keyless Entry Logo
772 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
