Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
My wife placed the filter in the wrong way. Our White-Rodgers Thermostat is saying filter malfunction and showing a flame when I turned it to heat. I went and put the filter in the right way be the thermostat is still saying the same thing. Is there a way to reset it or what can I do to make my heat come on and the thermostat to start working?
    Problem Solver:
  • 14 Answers
Yes try to reset it,you will see a really small buttons that says reset push it.
Posted on Feb 18, 2013
  • 22 Answers
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To better assist you with this contact us directly at 18002842925.
Posted on Nov 02, 2012
2 Suggested Answers
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Jan 16, 2016 | White Rodgers Home Security
White-rodgers 1f80-261 thermostat: Set to heat, "flame icon" appears but no heat and no fan. Thermo doesn't click when adjusting temperature. Set to fan,there is no fan.?
There is a 3 amp fuse in the main circuit board. If this fuse is bad ,nothing will work but because of the batteries in the thermostat it will lead you to believe that the unit is working properly,however, it is only showing you what is supposed to be. Replace the fuse and everything will work.
Oct 17, 2015 | Thermostats White Rodgers 1F80-261...
My White-Rodgers Model #1F78 5/2 Day Prgm thermostat turns on and ighnites for a few seconds then turns off even after reprogramming or resetting. What should I do next to get the heater to start working?...
If the furnace or boiler burners actually light for just a few seconds and then go out, the problem is probably NOT the thermostat. Most likely the thermostat is calling for heat so the burners light, but there is a safety device called a flame sensor that will shut off the burners if it does not sense the flame properly. It is very common for the flame sensor to get soot, dirt, or oxidation on it and then it can not sense the flame and the furnace does exactly what yours is doing. Most of the time the flame sensor can be cleaned and it will work again. Sometimes a new one will take longer to go bad again. Typically they are a straight or "L" shaped piece of wire about the size of coat hanger wire that just sticks into the flame. The coat hanger type wire usually goes into a white ceramic base which in turn has a wire connected to the back end. Steel wool works good to clean the flame sensor, but if you use coarse wool or coarse sand paper the surface of the flame sensor gets rough and gets dirty faster. It is made of some kind of "polished" stainless steel.
Dec 10, 2013 | WHITE-RODGERS DIV 1F78-151 White 70 Series...
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
Its saying MO in the upper left hand corner and AC won't turn on
Diagnostic: Set SYSTEM Switch to COOL and lower the setpoint below room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. Ifthe thermostat does not click, try the reset operation .If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks,contact the AC manufacturer or a HVAC service
person to verify the cooling is operating correct.
MO stand for MONDAY.
Jun 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I have a White-Rodgers Thermostat and it has the word (Filter) on the left side and a (Flame) showing on the right hand side, I'm not sure why we changed the filter two months ago. Does anyone know what...
Flame Icon is displayed when the SYSTEM switch is in HEAT position. Display "FLTR" when the system has run for the programmed filter time period as a reminder to change or clean your filter.
You can reset the counter by going inside the configuration table of the thermostat. If you need further clarification call our WR hometechline 18002842925.
Mar 07, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Auxiliary light was lite on my white-rodgers 1f82-51 thermostate and i have no heat?
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise
the setpoint above room temperature. Within a few
is operating properly. If the thermostat does not
click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
Mar 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My name is Tim Burke from White-Rodgers. If you hear the "click" the thermostat is calling. It would appear that their is a wiring issue to the funace. Please contact our customer service toll free hot line and they will be happy to walk you thru it and assist you. 877-978-7828
Regards,
Tim
tim.burke@emerson.com
Tim
Oct 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
321 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
