Question about Philips Magnavox TS3260C 32" TV
Tv turns on then turns off
The tv turns on then it turns off i tryed to unpluge it this did not work if you keep pushing the power button it will put a ble horizontal line on the screen
  • cayde2 Feb 17, 2009
    the picture wiggles also and the tv still turns off.
  • Anonymous Feb 27, 2009
    I have the same issue
    Scholar:
  • 141 Answers
A security system turns off the TV to protect the other components, keep pushing the power button is not a good idea.
The TV might have a diagnosis code. Watch the stand by light, if it's blinking in cycles.
\It looks to me that the power to the red or green or both bulb is troubled. It might be a simple card or the complete tube support. The power supply for those tubes might be also damage.
I don’t think it will be cheap to fix it. If you are a Techie try to download the service manual and open it, if not it might be very complicated to it yourself…
Posted on Jan 03, 2009
The power button is gone so there is no way to turn it on. is there anyway i can turn it on with the button?
You could try using a small screwdriver pushing straight in thru the hole where the power button was. If that doesn't work, put screwdriver in hole then push down on it. The switch inside the TV could be just inside the hole or up to an inch or so inside. To prevent electric short, wrap tape around screwdriver.
If that doesn't work, unplug the TV and take the back off, slide the circuit board out far enough to see how the power switch works then go from there. The actual switch is soldered to the circuit board. The power button is only a piece of plastic that actuates the switch.
Dec 03, 2010 | RCA Televison & Video
Will not turn on?
the lightining battery is not working very well. You should exchange it, so the TV power could get to the Tv and let it Work.
Feb 28, 2008 | RCA F36685 36" TV
My JCV 1997 TV will not turn on at all I'm missing the power button on the TV it broke and the remote control will not turn it on its been unpluged for month or so . No flaging light just blank. PLEASE...
Push the power button and hold. Check whether lights are ON.
If OK try whether you can keep the switch permanently in pushed
position. Try some paper stuffed tightly.
Otherwise replace the switch.
Aug 11, 2010 | JVC AV-27820 27" TV
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
Model: 32A43 Problem: Volume goes UP automatically. Channel scolls automatically. I tried using the remote and the buttons on the tv panel but neither works. I tried turning the TV off with the remote and...
check the front button plate on the front of the tv very carefully.if it has been hit with something and either or any button is pushed in,it will not listen to other commands.make sure each button has a distinct click when pushed.a frozen button will cause other things not to work.it sounds to me like two buttons are making contact,and they are beside each other,so the button plate is crooked or warped.
Jul 18, 2009 | Toshiba 32AF43 32" TV
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Mar 29, 2006 | Apex Digital PF2025 20" TV
Philips Magnavox TS3260C 32" TV Logo
109 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
