Question about Craftsman Vacuums
Craftsman 16gal wet/dry vac model 338.179230 runs when switch is held down
Runs only when i hold switch down.....replaced switch still doing the same thing
  • 9 Answers
SOURCE: Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Posted on Jun 18, 2009
SOURCE: USE GENIE WET DRY VAC WITH OR WITHOUT PAPER LINER?
I wanted to clean out my wood burning stove ashes. When I turned the vacuum on, the ashes blew out the top???? Is there supposed to be a bag or filter to keep this from happening?
Posted on Aug 05, 2009
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
kitt98
  • 26 Answers
SOURCE: How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Posted on Nov 05, 2009
shastalaker7
  • 1515 Answers
SOURCE: Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Posted on Jan 23, 2010
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
Who made craftsman wet/dry shop vacs in the late 70's?
here is a link that may be helpful
http://vintagemachinery.org/craftsman/manufacturers.aspx
it details the manufactuars that craftsman used based on then model and OEM number
Feb 08, 2013 | Vacuums
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The PB15 uses a fairly large pleaded paper filter for dry use, but it is an odd ball, as most of these type filters are held in place bay some sort of plate, and plastic nut. The PB15 uses a filter that has a bottom, and is pressed into place. For wet use, I would see if you can use the foam filter for one of the Craftsman small W/D vacs, like the old 2 gallon model, held in place with a rubber band, which is slipped over the cage with the float ball. It needs to be sealed across the bottom. That should cut down on spray making its way to the motor. The PB15 does have one good feature as the vacuum inlet has an elbow which keeps the water from being sucked straight into the motor intake, so the foam filter should do the job pretty well. I’d also look at the bag and rubber band that is used on some of the smaller Craftsman vacs, which sounds like what has been done on yours already. They are easy to find.
Because Genie no longer makes any vacuums or blowers, and did not keep a parts inventory to support owners of their products (a reason not to buy one of their garage door openers) it might be best in the long run to ‘garage sale’ the Genie, and buy a new vac from a brand that will be around for awhile. I have two Craftsmen, and one Ridgid, besides the PB15, which is going in the nest garage sale, for the above reason.
As far as your blower to vacuum problem -- The hose is moved from the blower outlet, which is the top black piece with the handle and switch, to the hole in the canister for vacuum. The intent of the PB15 was to use the top piece as a hand held electric leaf blower, or when attached to the yellow canister as a vacuum, when you use the hose attached to the canister.
Apr 16, 2009 | Genie Company GV150 Wet/Dry Vacuum
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Need replacement manual
Go to Sears.com, click on the parts link, put in your model number, a parts list will come up, if you manual is available, you can click on it to buy it.
Jan 01, 2008 | Craftsman 17740 Wet/Dry Vacuum
Craftsman wet/dry vac
It is supposed to have a round plastic plate and a plastic handle with a nut made in it that tightens against the plate to hold the filter on
Sep 01, 2007 | Craftsman 17026 Wet/Dry Vacuum
Vacuums Logo
74 people viewed this question
Top Craftsman Vacuums Experts
downhille
Andrew Taylor
Andrew Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
