Question about Canon PIXMA MX320 Color USB InkJet Printer
Closing cover on canon mg5320 printer
Cover will not close
SOURCE: Inner Cover error on Canon PIXMA ip4300 printer
This is a "Sensor" issue, there is a sensor that detects when the Cover is closed, this is either faulty, not being activated, or being activated but not registering at the CPU. Sometimes it is an actual switch, others it is a hall effect sensor, optical, magnetic sensor or the like. Have a squiz and see if ya can see any sensor etc. maybe its blocked etc. Otherwise I think it's gonna have to go 4 repair.. If so get a firm "Quote" B4 allowing them to proceede.
Posted on Aug 01, 2007
  • 5 Answers
SOURCE: my mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Posted on Dec 18, 2008
ic0729
  • 212 Answers
SOURCE: canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Posted on Mar 19, 2010
taran_2005
  • 10515 Answers
SOURCE: Canon MP830 LED Error 5100 'Inner cover is open.
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 09, 2010
SOURCE: My printer is a Canon
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
Posted on Oct 29, 2010
How do I scan a photo on my Canon MG5320?
1) Press the 'HOME' button on the top of the lid
2) Select the 'SCAN" button under the word "SCAN"
3) Use the "drop down" menu and select "PHOTO"
Jul 18, 2014 | Canon PIXMA MG5320 All-in-One Printer
Mine says "Inner cover is open. Close the inner cover and select 'ok'"
Perhaps you just need to press the door closed more firmly, or check for something caught in the door. Sometimes a stray bit of paper in the wrong place causes problems.
Mar 30, 2014 | Canon PIXMA MG5320 All-in-One Printer
Error code cooo
Go To Below official Canon Printer Page For Your problem,
http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 06, 2014 | Canon PIXMA MG5320 All-in-One Printer
Canon Printer MG5320 wireless printer
reinstall your printer drivers then. check your wireless connectivity.
Mar 09, 2013 | Office Equipment & Supplies
Pixma mg5300 reset
Ran in to this before and I think it took a trip to the Canon website under support and the model of the printer.
Jan 24, 2013 | Canon PIXMA MG5320 All-in-One Printer
Mg5320 no ink idicator
Sounds like the little canon needs serviced.
Jan 21, 2013 | Canon PIXMA MG5320 All-in-One Printer
Canon MG5320 is printing photos only with a purple tint
Try reinstalling your printers software, sounds like printer driver error.
Jan 20, 2013 | Canon PIXMA MG5320 All-in-One Printer
Edible ink cartridges for MG5320
I had the same problem and then found out that when I removed the "tape" from the cartridge, the part that was covering a small hole on the top of the cartridge was still "covered" which prevented air from allowing the ink to flow out.
It is a very easy thing to overlook but it did resolve my issue.
Jan 05, 2013 | Canon PIXMA MG5320 All-in-One Printer
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MX320 Color USB InkJet Printer Logo
43 people viewed this question
old marine
old marine
