My washing machine toshiba model tw-742ex(h) display E94
2 Suggested Answers
SOURCE: PC board of Lavamat 42260 Top Loader washing
Found that the water heater is giving low insulation resistance. It is being replaced by a new one.
Posted on Apr 15, 2009
Toshiba washing machine model aw-9771ubb error code e7-4
On washing machine error code e7_4 display and stop
Not working
Nov 10, 2016 | Washing Machines
Toshiba washing machine displaying e7-4 error and goes off after seconds
Listing the particular model will aid an expert in answering your question
May 22, 2016 | Washing Machines
I have an error code of E94 on my intex portable spa what does it mean?
If alarm code E94 is displayed on the control panel, it means the water temperature is too low. If alarm code E94 appears, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system when the spa water temperature is higher than 39?F (4?C).
Jan 25, 2016 | Intex Pool & Spa
My washing machine toshiba aw-b1100gm firstly when i on the button e7-4 display already,why?
NIK, LOOK IN YOUR OWNERS MANUEL FOR TROUBLESHOOTING FOR THIS ERROR MESSAGE,IF NO HELP TOMORROW CALL MANUFACTURER OF MACHINE HAVE MODEL NUMBER CALL CUSTOMER SUPPORT..THANKS
Jan 24, 2016 | Washing Machines
Model EWF1048W. Won't start. What does error e94 indicate?
E94 - Washing cycle configuration error.
Incongruence of configuration values at the switching on of the appliance. Check that all the connectors are inserted correctly.
Possible configuration error. Replace the circuit board.
Dado
Dec 12, 2015 | Electrolux Washing Machines
Electrolux time manager 7kg washing machine keeps stopping mid cycle and has an error code E94
E94 means: "Console control problem. Replace control board."
However fault codes are not absolutes. They simply tell a service person where to look for a problem. For example, if i was a service man and i had a control board like yours on the truck i would switch it out first to see if it solved the problem. If it did i would charge you for the part and labor and be on my way, even if it was just a loose wire or connector that was causing the problem. Or if i was a washer warranty rep and the machine was under warranty and you said you were getting an E94 fault code i'd ship you a control board and consider the problem solved.
I am not a service man or a warranty rep so my advice is to wiggle the wires going to the control board. Also, disconnect then reconnect any plastic conectors you see. Let me know.
Jan 30, 2013 | Electrolux Washing Machines
Sir good evening i have cash regester casio 160cr.Error code is e94 pls help how i can run my cash regester thanks.
I suggest you to reset your equipment.Here is how:
Remove AA batteries and unplug register from wall for 15 minutes.
Two more options;
Option #1:
To print the transaction details before clearing the journal memory:
VERY IMPORTANT: Do not interrupt once printing begins or the journal will not be cleared.
1. Make sure the paper is full in the register.
2. Turn to Z mode.
3. Hit the RC key until the screen displays "E94".
4. Hit Cash Amount Tender.
Once the printing is completed, the journal is cleared and the register is ready for use.
Option #2:
To clear the journal memory WITHOUT printing the transaction details:
1. Turn to Z mode
2. Hit RC key until the screen displays "E94 Clear"
3. Hit Cash Amount Tender
Nov 27, 2010 | Casio Parts Cash Register PC Desktop
PC board of Lavamat 42260 Top Loader washing machine. (Automatic) Washing Machine stopped on cycle and displayed E94 on panel.
Apr 14, 2009 | AEG Washing Machines
Machine was working when at a point it commence to show E94 and stopped functioning.
E94 incorrect configuration of wash cycle.
Could be a job for an engineer. Do you know how to safely drain machine? If so manually drain water from machine, then check the pump, (bottom right front corner) for obstructions. If you have not done this before, proceed with caution. You will need towels to soak up mess.
Apr 04, 2009 | AEG Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
