Question about Kenmore 24032\24036 Top Load Washer
Sears manual kenmore 80 model # 24862300
How to remove agitator
mikedurland
  • 481 Answers
SOURCE: Sears Stock# 28803 / Model# 110.28803890 / Kenmore 80 Series
this sounds like the direct drive coupling between the motor and transmission. very common problem and not very expensive. look under the machine and and between the motor and transmission you will see a round rubber coupling and 2 plastic pieces one on either side; they all connect together to mate the motor and trans without a belt.
Posted on Jun 27, 2008
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
  • 115 Answers
SOURCE: Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Posted on Dec 31, 2008
SOURCE: Sears Kenmore 80 series washing machine Model 110.26832691
How do you remove the top of a kenmore washing machine? I have a mouse stuck in the lid and can not get the top off.
Posted on Apr 30, 2009
hiltonjug
  • 612 Answers
SOURCE: series 80 kenmore washer floods
You have a bad selector switch. It's the one that you use to set the size of the wash load. It turns the water valve on and allows the machine to fill to the level of water you have selected. When it goes bad, it will not open to tell the water valve to turn off once the water level has been reached that you have selected. This is why it's over flowing. You can change the switch with little effort. What you will need to do is take the plastic covers off of each end of the console. To remove, pull forward on the top to un-clip. Once you have removed both end caps, take the screw out of each end that you will see once the covers are removed. Now pull the whole panel toward you and lift it up. It will pivot over the back of the machine. Now you will see the back of the console where you can remove the bad switch. You can find the switch anywhere that sales appliance parts. One on the web is www.partselect.com I have found that they have the best price on most parts. Just enter you complete model number and it will bring up a blow up of your machine where you will be able to find the part and also order it with a credit card. Good luck and have a great day.
Posted on Oct 18, 2009
Owners manual for sears kenmore washing machine type 588-08 model number 110-21102011
Many Kenmore appliance manuals are available from the Sears Parts Direct site: http://www.searspartsdirect.com/ . The manual page for the 110.21102011 washer is http://www.searspartsdirect.com/partsdirect/user-manuals/11021102011-Kenmore-Parts-Washer-Parts-manual?searchTerm= if you want to read it in your browser. (A PDF plugin is needed.) The direct link to the manual is http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/1009787L.pdf if you want to read the document in your PDF reader software.
The parts diagrams may be more useful for how to remove the agitator. Those are available here: http://www.searspartsdirect.com/kenmore-parts-washer-parts/model-11021102011/0582/0153200.html?searchType=modelSearch&prst=&q=11021102011&searchTerm=11021102011&shdPart= . The agitator is shown in the Basket and Tub Parts diagram: http://www.searspartsdirect.com/kenmore-washer-parts/model-11021102011/0582/0153200/K1103004/00003.html .
I hope this helps.
Jul 30, 2015 | Kenmore Washing Machines
I have a kenmore heavy duty 80 series top load washer model 110 and it is no longer agitating. I think it is the dogs that need replacing but the white portion of agitator itself looks a little worn. ...
well i would recommend repacing agitator and agitator doggs ... get complete model number off washing machine data place got to sear.com and select partsdirect enter model and order parts they will send directly to you...
Jan 28, 2011 | Kenmore 24032\24036 Top Load Washer
The agitator is slipping on our Kenmore 80 series toploader. I'm not sure how to remove it.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
Assuming that only the top section of the agitator is "slipping, the problem points to the Agitator "Dogs"
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=8878c06f855a89c90959d53553cf9ab8
If it's not the "Dogs" see the following that has a section on how to remove the agitators and check the splines.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Mar 02, 2010 | Kenmore Washing Machines
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
Bottom part of agitator does not work, i replaced the clutch dogs two weeks ago for the top part. kenmore series 80
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are a number of Series 80 design washers. You'll need the actual model number to better check for the problem.
First, I'd remove the top agitator (as you've already done), then I'd remove the main agitator.
Under it you will see a clip and what Whirlpool calls a "washer". The "washer has two prongs, one fits into the main agitator shaft drive and the other fits in the lower agitator. If one or the other of the prongs is broken, the agitator most likely wont. I'd also look inside the main agitator to see if the ridges are broken off.
I'd then start the washer on it's smallest cycle and see if the main agitator shaft turns back and forth. If it doesn't and the washer goes through it's drain and spin cycles, the problem is likely in the transmission itself with what they call the agitate gear and / or agitate cams.
Please see the Whirlpool / Kenmore PDF document on installation, maintenance and operation of direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
This is a Whirlpool document with parts lists for their commercial washers (basically the same as the consumer models)
If the problem is in the transmission, although it looks complicated, it really isn't that bad if you have a moderate level of mechanical ability.
Sep 26, 2009 | Kenmore 22422 Top Load Washer
Agitator: bottom moves, top does not
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 seies - agitator slips and doesn't turn in regular motion
There are 4 agitator dogs under the dasher go to sears,com you can pull up the diagram with your complete model number and order them right there online....
Jul 08, 2009 | Kenmore 24032\24036 Top Load Washer
May 24, 2008 | Kenmore 24032\24036 Top Load Washer
Model 80 Sears Kenmore washine(Remove inner basket)
under the agitator youll see a lock nut appox 2-3in, around "locking" the inner basket to the outer basket. although they do sell a spanner wrench to remove this nut, A decent pipewrench and little muscle will get it loose, after that the tub will pull right out. assuming youve taken off the outer tub gasket cover
Mar 09, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
