Question about Electrolux Washing Machines
My electrolux front loader has a code 4
All the lights on the control panel are on and there is a 4 on the display screen
  • Official Brand Answer
  • 4,342 Answers
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to display 4. If it proves to be ineffective, contact a professional to move forward accurately. Washer could be experiencing a communication error with control board or wiring failure.
Posted on Nov 01, 2012
SOURCE: unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Posted on Apr 12, 2008
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
mnwarfield10
  • 452 Answers
SOURCE: Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Posted on Dec 30, 2009
torres No9
  • 27 Answers
SOURCE: My 7.5kg Electrolux Washing Machine whent bang and
your door lock has blown/short circuit turn power of disconnect plug take top of machine look down inside machine toward door lock and you shoud see the catch push hard with your finger and door will open be careful as there are some sharp edges in there.
Posted on Jun 25, 2010
rickead1
  • 1998 Answers
SOURCE: Hi - My Electrolux XL
if you have no power going to the control panel then it would be your plug that your having the problem with cord of the machine this is a very common thing to happen inb machines simply find where the plug goes into the back by removeing the top panel and assure that you have power coming in to the unit if you have any further questions message me back and pleae remember to rank how this opinion has helped it allows me to continue to help others with similar situations Thanks again Rick
Posted on Jan 26, 2011
I have a Electrolux front loader and im getting an error code of e35 what does this mean
Signals washer has overfilled, pressure hose or pressure switch most likely
Dec 25, 2014 | Electrolux Washing Machines
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
May 07, 2014 | Zanussi ZWF1640 Front Load Washer
Dryer electrolux indicates code E64
you will have to take the front panel off. first unplug the dryer then there will b two screws in back that hold top on, once screws r out the top will slide back allowing to lift up. there r 4 screws that hold the touch/display panel on. unplug and remove. there r another 4 screws under that panel that hold the front panel and there 2 more when u open door about as high the lint screen. once all screws r out u should b able to see heater. if not remove all other necessary components. it will b at the bottom left. remember this usually the cause of a heater failure is a clogged or restricted vent. tall tell sign close took a long time to dry.
Feb 16, 2013 | Electrolux EWMED65HSS Electric Front Load...
Front loader washing machine EWF1087 stopped half way and did not drain, E50 was displayed. Emergency emptying out the water was done and try to restart. Could not start, still displaying E50. What to do?
the error code E50 indicates that the motor has become overheated, you should give it an hour to cool then try running the washing machine again. I'm also including a link to pdf below with the common error codes for your brand of washer in case you have any other problems
http://www.applianceblog.com/mainforums/attachments/frigidaire-electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwashers.pdf
Jun 17, 2011 | Electrolux Washing Machines
Hi I have an electrolux front loader model number E/EWF1087/W I switch it on and all the green lights flash and I have an error code reading 'err90'. Can you please tell me what this is and can I fix it...
Sorry to read about your problem, I hope this helps you out.
e90, means a bad connection. at the main control board.
you can try to open the machine and check a and clean all connections to the main board.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Electrolux EW1000i Front Load Washer
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
