I have a Sandisk flash drive that isn't recognized by my computer
It has a long history of working correctly. I used it on Tuesday to bring up and print a file. Later that day the same computer wouldn't recognize the flash drive. Today I tried it in another computer and again it isn't recognized. I read other reviews that said to go to Hardware tab of my computer but the problem is you can't see the device there.
    Sergeant:
  • 302 Answers
This the sign of a permanent mulfunction. A tiny capacitor is bult into the drive to manage power supply and when that capacitor is blown / fired, due to moister or excessive power flow. Your drive is useless now and you need to consider replacing it with a new drive.
Posted on Apr 29, 2013
    President:
  • 2,976 Answers
I had the same problem. If you removed the flash drive without clicking the "Safely remove device" icon in your running processes window, and then individually shutting it off, you might have made it virtually unuseable. I have 2 "keyrings" now. I switched to another brand that you can just pull out when you're done using it.
Posted on Jan 03, 2009
Why is my computer not recognizing my thumb drive?
I've seen this due to not having the correct drivers on your computer that support the connected flash drive. Visit the flash drive manufacturer website and look for support there. You may be able to download a driver. Be sure to know what you operating system is because that may matter to select the correct drivers.
Jun 16, 2014 | SanDisk Electronics - Others
It says that a problem occurred during instalation and it may not work properly. now i can't get it recognized on any of these computers
If you can't even get your drive recognized in any of those computers, there's nothing you can do. If you are inside the warranty period (For SanDisk it is usually 5 years since the date of purchase), then take it to your dealer. He will bring you a replacement within 2 weeks. Even though you are outside the warranty period, take it to your dealer to see if he can do anything on it. Sometimes, you would be lucky.
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Regards,
Sunny.
Sep 01, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I NEED A DRIVER FOR MY SANDISK USB, COZ I TRY ALL I SHOULD TO RECOGNIZED IT BUT AFTER ALL THE DISABLE, UNISTALL, RESTART, SHUTDOWN... STILL USN UNRECOGNIZED... WHAT SHOULD I DO?
Everything your Sandisk Cruzer USB driver needs to run should be on the usb drive itself, unless you have erased it, in which case you may have a problem.
The correct way to use a Sandisk Cruzer is to plug it in so that it lights up and then not touch anything on your computer until the orange sandisk symbol appears on your desktop. Right click this app and use it to browse your USB drive and eject it when you are done.
I hope that helps.
Aug 30, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
VAIO desktop does not recognize Sandisk flash drive
Most probably you have a drive letter conflict? If so, right click "My computer" choose "Manage" and locate "Disk management" - here, in the middle lower panel, you should be able to find your usb-memory stick, right click it and assign it a drive letter that you're sure is not in use.
Jun 01, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
Password/Data Recovery
Try them in another user name, or if still no good try another machine. Go into "my computer" and see if it is showing the drives are recognised, if not restart the machine with the drives connected. If you still can't get in, you may have to call sandisk to get a solution from their proprirtary software. If you used another user account,or machine, that may be it
May 14, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Computer won't open program to import
#1. Reboot the computer.
#2. is the light coming on the card reader when you insert the card? If not, the computer is not recognizing the card. Make sure the card reader is plugged into a working USB port and the card is inserted in the correct orientation. If the light is coming on, simply go to "My Computer" and select the drive letter associated with the card.
May 19, 2017 | SanDisk ImageMate 12-in-1 USB 2.0 Card...
SanDisk Cruser Micro
sounds like the usb ports on your computer are going dead.. You may have to use your drive on another computer to retreave data then put it on cd..
Nov 21, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
