Question about Sharp 25H-M60 TV
Help with my tv
Hello, I was given a sharp model 25h-m60 tv. I wanted to hook up my dvd player to it, but I noticed there were no audio/video connections. Does this tv have them? is there a way to hook up my dvd player? Please help!
    Problem Solver:
  • 14 Answers
Some tv's dont come with rca jacks, what u can do is run your rca's through a vcr and then the vcr to the televison u can do it that way, or take and buy this thing they carry at radio shack, it is a devise that you can hook your dvd player to a junction box that hooks into the same place as a vcr would in the back of your tv, hope this helps jason
Posted on Dec 28, 2007
My 26" 1997 Sharp T.V. model #25H-M60 turns off by itself and won't turn back part of the time.
First thing if you are able is to unplug set and remove rear cover (lay set face down on a padded surface).
entire main board should be able to be seen or released so it slides out--take a very careful look at flyback and rest of board for any cracked or bad solder connections.
One bad connection (age) can cause this.
5_21_2012_3_10_50_pm.jpgtypical high voltage transformer which is also called a flyback transformer.
May 20, 2012 | Sharp 32L-S400 32" TV
1996 sharp tv model # 25H-M60 co-ax pulled out from the circurt board. I removed the back of the tv,and can see the female end is snap off the case that houses the board. Can i solder that back to the...
That is what the service provider would do if you took the television in to be repaired. The service provider would attempt to solder the rf connector back to the television or solder a new rf connector to the television.
Mar 29, 2011 | Sharp 19H-M60 TV
I have a problem conecting my sharp 25h-M60 with my DVD plyer.I have found solution on Fixya. They said I have to use VCR. My question is: What does VCR mean?
If your TV does not have AV inputs (RCA jacks for video and audio), you can't plug the DVD player directly in to the set. One solution is to connect the DVD player to a video cassette recorder (VCR) using the "line in" jacks on the VCR, then using the channel 3 or 4 output from the VCR to the TV. This solution may not work with discs that have copy protection, though, and will give you an unwatchable picture.
For sets with no AV input, you need an RF converter. This is a device that takes the video and audio signals from a DVD player or other device and makes a channel 3 or 4 TV signal to the TV's antenna connector. Converters are available at most retailers where you can buy televisions, as well as online.
Jan 01, 2011 | Sharp 25H-M60 TV
Sharp 25H-M60 landlord broke off the cable connector!
depends i have replaced these alot the part is cheap but you have to be careful when repairing this problem you can really mess the tuner up then it cost more starts any where from 40.00 to 80.00 dollars the parts cost pennys okay it's all labor have a good day tv man
May 14, 2009 | Sharp 25H-M60 TV
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
Hooking a dvd and vcr to a cable box and tv
You will have to use an audio/video cable for connecting the player to the tv. This cable consists of three wires, generally a white, a red and yellow. Yellow is for video and the other two are for audio. You will find corresponding colored sockets both behind the tv and the player, find out which is the input at the tv and output at the player. Good luck
Jan 30, 2008 | Sharp 25H-M60 TV
DVD PLAYER
what kind of dvd player is it, is it for your home? car? and what kind of tv is it goin to? get back at me, jason
Dec 28, 2007 | Sharp 25H-M60 TV
Hooking up a Phillips DVD player
may have to change rca cables or s-video cables, or maybe try a new reciever, or maybe goin from dvd player straight to the plasma? hope this helps jason
Dec 06, 2007 | Sharp 25H-M60 TV
Hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Nov 24, 2007 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Televison & Video Logo
229 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
