Question about Electrical Supplies
Power boss 7000 generator won't start
Won't start. it seemed like it was going to start but didn't
sal_kh_sab
  • 98 Answers
SOURCE: our onan generater runs but the power in the rv comes & off,
if ur problem is why does it get loud when the power is off...the answer is GLATOR calibaration..
if u have any further questions email me at sal_kh_sab@yahoo.com
Posted on Oct 15, 2009
  • 342 Answers
SOURCE: Generator won't start. Seems to
have you had the generator stored with fuel in the carburettor since its last use if so the fuel goes bad and blocks up the main jet, remove the float bowl and clean out all the residue you can clean out the main jet with a suitable piece of wire
Posted on May 30, 2011
SOURCE: Getting NO power from the MR2 160/2 Mecc Alte Spa
There are a few more components to check in the system. From the information provided this is not a Kohler generator as Kohler makes all their own AC alternators under 350KW, seems you may have just a Kohler engine (probably a CH25). Cannot find any info on the voltage regulator which leads me to believe it may be integrated into the main controller. Curious to know who the manufacturer is. If the capacitors are good, try checking the diodes. A volt/ohm meter with a diode check will do. Voltage reading on one side and nothing on the other. If you have no access to a diode check feature, try reading it through a battery NOT SHORTED TO BATTERY hook a meter to a battery and put the diode between one of the leads to the positive, one way will read voltage the other will read open, no voltage, or OL. Look for any fuses or breakers blown / tripped. 6 VAC on the output is about residual voltage meaning voltage the alternator makes without any help from a voltage regulator or field voltage. This usually means the alternator / rotor windings are still good. This alternator is brushless so you could seperately excite this unit via a 12V battery through your field. Look for your exciter field winding, it should have some kind of label on it saying F+ and F-, apply 12V here momentarily on + & - respectively with the unit running and you should see your output voltage spike. This tests the alternator. If this tests ok, then check to make sure your wiring / fuses from the alternator to the controller or voltage regulator (voltage sensing leads) are ok. If all these check ok, it is likely you have a bad voltage regulator.
Posted on Jul 16, 2011
  • 13 Answers
SOURCE: I have an overload alarm on my honda eu2000i
it may be a thermal coupler that cuts out when it gets to hot i would let it cool off for a bit then try it with a lighter load and go from there
Posted on Jul 28, 2011
Mr BrokRench
  • 1623 Answers
SOURCE: Our Honda EB 3500 generator
It's either not getting enough fuel, or the govenor is not working. When the engine is running, watch the throttle linkage between the carburetor and engine, looks like a bent wire. When you throw a load on it, it should move to give the engine more power, if it dont, try moving it by hand.
If that appears to be working ok, check the fuel line from the tank to the carb for good gas flow.
You can also remove the float bowl on the bottom of the carb, it's a round bowl on the bottom of the carb with a bolt in the middle of it...clean it out and check the float. The float looks like a little catamaran, make sure it is moving freely up and down. That is about all you can do without removing and cleaning the jets in the carb.
Good luck, & i hope this helps.
Posted on Aug 27, 2011
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
Dressmaker sewing machine 7000 thread won't move
something could be wrong with the feed dogs, it's would be a
good idea to have them checked.
Jan 08, 2013 | Sewing Machines
Brand new genpower 8kva generator wont start
Thankyou Keithdandy. It seems you know what you're talking about and even read the bit about it being a DIESEL (no plugs or carb). It's dark and we're tired now but we will certainly look at the valves first thing in the morning. (the mist bit gave it away!!) thanks again.
Nov 23, 2012 | Electrical Supplies
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
Why won't my Homelite 720 watt Generator start?
hi am elie hawzi i have generator 720wat homeliet had to run wer can i put 2 storc oil in my generator pleas do you have any adia haw can i leave the generator run stridaway thanks for fixya
Jun 28, 2012 | Electrical Supplies
Generator not producing power
You're too lazy to give any details so don't expect a solution either.
Jun 21, 2012 | Generac 5625R GP7000 GP Series 7000 Watt...
My Subaru backup generator won't start. It started fine last year and ran for about a few days. When I stored it I just shut it off and put it away, didn't add any additives or anything, now it...
you need to take the carburator off and clean it as well as the fuel tank,to start,maybe even a spark plug as well.always use a gas stable additive when you store it,better yet try to get in the habbit of running it once a month
Jun 12, 2011 | Coleman Powermate Subaru 5000W Portable...
Electrical Supplies Logo
70 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
