Question about Toro Power Lawn Mower
My toro lawnmower rear wheels wont disengage
The self propelled wont disengage
#1 Taper
  • 1040 Answers
SOURCE: SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
Posted on May 30, 2009
SOURCE: Toro 6.5 self propelled lawnmower stopped self propelling! T
Removed all the debris that had wound around the front wheels and it works again. Thanks for the help.
Posted on Sep 04, 2009
  • 8404 Answers
SOURCE: Toro self propelled mower rear wheel keeps falling off
Are these regular bolt on wheels? Have you changed the nut?
I would expectc to find a "Stover" nut on such an appllication. Stover nuts are similar to "NY-Lock" but without the nylon lock. Rather, Stover (and you have to ask for them at the hardware or auto parts place), are not round and/or have had a certain side portion punched to make the nut hard to put on. Some well meaning back yard mechanics (read me) have 'fixed' the Stover by running a tap through them maning them easier to get onto the threads ... but alas, it didnt stay. That was how I learned about Stover.
Let me know if this helps.
A
Posted on Sep 21, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
wadembly
  • 448 Answers
SOURCE: I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Posted on Nov 10, 2009
I have a toro self propelled 6 hp lawnmower battery and pull start it wont start with battery but will with pull cord
Try to start it using jumper cables to boost it from another battery. If it starts, your battery needs replacing.
May 21, 2015 | Toro Lawn Mower With Toro Power Tools
My toro 20624 lost self-propelling after the blade hit a baseball
check for the belt being off pully under lawnmower
Sep 16, 2014 | Garden
Where is the primer bulb o my toro lawnmower
Typically a primer is only used on 2 cycle engines not on lawnmower engines, so it would not have a primer bulb.
Jul 15, 2014 | Toro Garden
Toro self propelled rear mower recycler.. starts and runs fine..Then stops if you do not keep the propulsion in gear
I would say that something inside the mechanism that engages the self-propelled action has broken. When you release the lever, (most of the way), that keeps the S.P. action moving, it's suppose to flip the action off but keep the motor running. And when you release this same lever all the way, it acts as a kill switch. If your wheels never disengage, then I would look at the mechanism spoke of above.
If you hear this mechanism click when you release this lever, this is good and it's not broken. Then you may have grass and junk clogged up under the cover where the front wheel is. This would also keep it from disengaging.
Good Luck!
Jim
Aug 19, 2011 | Toro Power Lawn Mower
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
How would I get an owner's manual for a Toro
go to www.troybuilt.com u can request one on line or can be advised where to pick one up
Mar 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Sep 03, 2009 | Toro Lawn Mower With Toro Power Tools
6.5 toro walk behind self propell b&s engine. self propel does not work
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
Aug 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Power Lawn Mower Logo
60 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
