Question about Acer Aspire 5520-5908 Notebook
My dvd-r does not read discs or anything, i've tried looking at my computer management bit and it says its working fine, and i've uninstalled it and re-installed it and it still don't work, a friend has said to try remove it and start my computer then turn my computer back off , put it back in and then it might work again, what do you think? how do i remove it? its an acer aspire 5520
    Master:
  • 413 Answers
I found this page that describes how to remove the drive in a 3000, it should be similar to the computer you are running
1) remove the side panels from your case.
2) disconnect the drive cables from the back of the old drive.
3) remove the mounting screws holding the drive in place.
4) remove the old drive.
5) look at the jumper setting on the back of the old drive to determine if it is master
or slave.
6) make sure that the new drive's jumper settings match that of the old drive.
7) insert the new drive into the bay that the old drive came out of.
8) replace the mounting screws to secure the new drive in place.
9) attach the drive cables to the new drive.
10) put the side panels back on your case.
11) boot the computer and confirm that windows recognizes the new drive.
http://www.hardwareanalysis.com/content/topic/56818/
Please let me know if i can assist you any further. If this is what you needed please let me know by rating the solution as FixYa
Posted on Jan 03, 2009
sandrew
  • 2961 Answers
SOURCE: ACER eRecovery management
go here and select empower and your operating system
http://support.acer-euro.com/drivers/notebook/as_5610.html
Posted on Aug 31, 2008
  • 41 Answers
SOURCE: acer aspire 5520-5534 video driver
http://support.acer-euro.com/drivers/downloads.html
You can get your driver Here...... :)
Have a nice day......
Posted on Oct 31, 2008
preachw996
  • 1179 Answers
SOURCE: acer aspire 5520 ethernet driver
Here is a link to your driver page. You will have to select the operating system you are using & proceed from there. This will give you all available drivers for your system. Hope this helps & please rate this solution fixya. Thanks.
http://support.acer-euro.com/drivers/notebook/as_5520.html
Posted on Feb 05, 2009
SOURCE: Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
Posted on Aug 14, 2009
LaptopExpert
  • 458 Answers
SOURCE: my acer aspire 5520-5334 won't start
Pull The Battery... Unplug The AC Adapter....
Press and Hold The Power On Button For 30 Seconds...
Reinsert The Battery, Plug In Ac Adapter... Attempt to Power On..
Also Try Removing The Battery And Powering Up Using The Power Cord Alone.....
If Still No Power.... Remove and Reseat The Memory Modules...
Still No?
You'll Next Need To Check To See If The DC Jack Is Faulty...
If It's Faulty, You'll Need To Desolder It, Clean The Board, Resolder a New One ON....
Check The Heatsink/Fan Assembly...it might be clogged...
Still No?
Possibly Faulty Video / GPU Chip....Or a Shorted Out Motherboard..
Posted on Dec 01, 2009
Optiarc 7580s dvd does not recognize any disk
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Mar 04, 2012 | Sony Optiarc Computers & Internet
Dvd drive noisy put in dvd go to my computer driver is showing but wont play driver ejects
1. Try a different cd or dvd to see if it's reading any dics
2. Boot computer and try again
3. Uninstall the dvd drive from your computer (windows xp machine) , Right-click "My Computer-icon" -> Manage -> Device Manager -> DVD/CD-rom Drives -> right-click and select uninstall Restart the computer and it should install the drive again automatically Try reading the discs again
5. Update driver if available, see manufacturers website for driver updates
6. Try the dvd drive in another pc (if possible)
7. Propably faulty drive, replace the drive with a new one
Mar 06, 2011 | Computers & Internet
Can't recognise DVD RW
Hi all,
Boy, have I been having a problem. I've tried two different dvd burners, an external TDK DVD+/- RW drive and now an internal NEC dual layer DVD+/-RW drive. I have a Dell Dimension 4500 that came with a Dell branded Windows XP Pro. Have you ever tried getting support from Dell? What a freaking bad joke that is.
Microsoft says there is known problem with XP viewing a DVD+/-RW disc the same way it views a CD+/-RW disc. Problem is a CD RW uses 32 bit packets and a DVD RW uses 16 bit packets. As a result, without the fix, my computer can't recognize there is a DVD RW disk in the drive when trying to burn to it. It recognized DVD +R and DVD-R discs just fine, and I am able to burn to those with no problem.
What I want to do is image my hard drive and burn the image to DVD. That I can't do, because it always comes up with "no disk" or some variation thereof anytime I try to write to an RW disc. Any suggestions? Has anyone else had this problem?
Feb 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My DVD+/-RW with labelflash recently stopped reading DVDs, CDs, and select data discs. Some discs read instantly without a hitch others aren't even detected. There is no disc error message. They are either...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 03, 2011 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
Dvd read/write disc will read files but won't write files
Try uninstalling the DVD drivers from , Device manager
1 .click on start menu
2. right click on computer
3. clcik on properties then click on device manager
4 you can see dvd driver listed
5 click on the + or triangle on the left side of it so that it would drop down
6 right click on dvd drive then click on Uninstall
7. Restart the system then check for working using the software which is listed in the this link http://cdburnerxp.se/
Nov 16, 2010 | Dell XPS M1530 laptop. TUXEDO BLACK. 15.4"...
Toshiba dvd R/RW =/- TS-H552D/GAAH just quit on me. It will not recognize anything I put in it even though the light and the front flashes like it is trying to. Yesterday I was copying me cd collection and...
Since it is not reading any of the discs it usually means it is driver issue or the drive it self. Easiest way to see is it driver is to uninstall it and restart your pc. Once it is up it will tell you it has found new hardware and it will install it. Once it says it has been installed try to read a cd again, one you know it works for sure. When you go to my computer if you can see the drive it self it means it is not connection issue. To uninstall it:Right click on My computerand click manage. Once in manage on left pane select Device Manager. In the next window that opens on right side you will have all the devices that are installed on your pc. One of them will say DVD/CD Rom drives if you have a DVD reader or just CD Rom. If you click on little arrow next to it it will show you what is there, You gonna right click on your DVD/CD drive from here and click uninstall. It will ask are you sure and just say yes. Once it is done restart your pc and once restarted give it about 3-5min to finish installing the drivers. If this does not work you might want to replace the reader it self. They are pretty cheap these days, like in Walmart, BestBuy or any other store that sells PC parts. Hope this helps and good luck.
Jan 09, 2010 | Gateway GT5220 PC Desktop
Advent 7113 will not read cd drive
This could be the lense giving up.
Try a few different disc type (eg CD's DVD's CDrom, DVDrom etc) - if any of them work, that should indicate the laser is fine all round.
I'm trying to sort my Advent 7110 laptop at the moment, you haven't a recovery disc have u? LOL! Seriously though have ya?
May 10, 2009 | Computers & Internet
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
My laptop Not reading any CD/DVD
Go to Device Manager by "right-clicking" on "MY COMPUTER", and choose "MANAGE". Once the new window comes up, look for "DEVICE MANAGER" on the left hand side of the screen and click on it.
On the right hand side of the screen you will see a long list of items, look for DVD/CD DRIVES and click on the + sign next to it to expand that list. Now look for your DVD/CD drive and right click on it and choose uninstall. Then restart your computer, when it restarts it will say "FOUND NEW HARDWARE, ATTEMPTING TO INSTALL" wait for it to finish and tell you that it's ready and try to insert a disc. If it does not read it, the Drive might be bad so you might have to replace it...Good Luck!
Dec 02, 2008 | Computers & Internet
Acer Aspire 5520-5908 Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
