Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Will talkabout 250 communicate with cb
Want to know if I can communicate with a cb
  • Motorola Master
  • 1,654 Answers
No. Your Talkabout T250 operates on FM UHF frequencies between 460-470 MHz. The CB operates on 40 frequencies between 26-27 MHz.
Best regards.
Posted on Oct 27, 2012
4 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: talkabout 250 screen cracked
Sorry, but the answer is no. The fact you cannot change channels indicates the damage is deeper than just the screen.
Posted on Jun 26, 2009
SOURCE: How to get a Talkabout T5720 to communicate with a
Actually a P100 is a 4/1 watt radio in UHF. It has a high low switch on the top. So, you could add GMRS frequencies to a P100. Also called an HT50. P100 radios are so big compared to the smaller radios of today, I use a couple as pseudo base stations.
Posted on Jul 10, 2012
chris_baden
SOURCE: Antenna for a Motorola Talkabout 250
Get a plastic tube (3/8 PVC will work) and use it as a mould. Pump it full of black RTV silicone. Fixed!
Posted on Oct 20, 2012
How do you transmit from a cb radio to a talkabout fr60 and vice versa
CB radios and TalkAbout FR60 radios will not communicate together. CBs are 26-27.5 MHz and TalkAbout radios operate on FRS and GMRS frequencies between 462-467 MHz.
Best regards.
Oct 10, 2014 | Motorola Talkabout FR60 (14 Channels)...
The U-shaped bottom of the radio will slide down and off the radio, it will include part of the back of the radio.
Jan 04, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
I changed the batteries on my Motorola Talkabout 250 .......shows full power...both are set for the same channel and code.......but they aren't communicating. Please help.
Remove batteries from both. If there's a "factory reset" option try that. Re-check that they are REALLY on the same channel and code. Also be sure there's nothing stuck in the external headset jack.
Aug 11, 2013 | Motorola Talkabout FRS 250 (14 Channels)...
I need a user manual for motorola talkabout 250
The closest user guide we have located online to the T250 is a step newer, the T280. Here is a link: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
Best regards.
Dec 30, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
Does the T/A 250 use standard CB fequencies?
No. The TalkAbout 250 has 14 FRS frequencies built in to it. These are FM UHF 2-way radio frequencies which differ from CB frequencies.
Best regards.
Mar 04, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
Can i get CB communication on my t5820
Sorry but the answer is no. Your TalkAbout T5820 is an FM radio operating on FRS frequencies in the UHF range (462-467 MHz). CB radios are AM radios operating between 26.965 -27.405 MHz.
Best regards.
Aug 16, 2011 | Motorola Talkabout T5820 (14 Channels)...
Want know how to open the battery compartment for motorola talkabout 250 2 way radios
The U shaped sides are attached to the back. It slides together down and off the unit.
Sep 03, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Installed a cobra CB ultra III on a motorcycle
The external speaker jack was not designed for a head set. It has too much power it over loads head set. You need to solder a resistor in line with the negative wire. You will have to experiment to see which value gets the audio just right for the head set you are using.
Jun 13, 2009 | Cobra 19 Ultra II CB Radio
I recieved a talkabout 250 and i have no clue how to use it please help
You would need two or more radios to be able to communicate with others. Then you simply press the push-to-talk (PTT) button when you want to talk (transmit) and release it so others can reply (receive). The radios must be set to the same settings to be able to communicate.
Apr 11, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Cant pick up on cb radio
No, T5700 radios operate on UHF FM frequencies in the 450-470 MHz range. CBs will not communicate with them.
Jan 31, 2009 | Motorola Talkabout T5700 AA (22 Channels)...
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
188 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
