Question about Honda 3000 Watt Portable Generator
Got a stuck intake valve on a eu 3000 honda generator?
3 Suggested Answers
  • 14 Answers
SOURCE: Honda 3000 eu no spark replace ing coil still no
Is there enough oil in the crankcase? Many generator ignition problems come from the oil level sensor. Either not enough oil or the sensor being bad.
Posted on Aug 01, 2010
r_fuller297
  • 573 Answers
SOURCE: gas in oil
First of all check to see you have a good spark, If it is running fine under load ignition should not be an issue. If un burnt fuel or over fueling causes the oil / gas to wash down the cylinder walls. I would also perform a leakdown test not a compression test, remove the dipstick and listen for air coming out the crankcase, that will give you an idea if you ahve a ring problem. Also remove the air filter and see if you have any blow back from the carb blowing out where the choke butterfly is. If it has less than 150 hours on it, the rings may also not be seated in, try the above then run it hard on load and check it again
Posted on Dec 10, 2013
Gas getting into crankcase has new carburator
Sounds like the float is not set properly or the needle valve is not seated properly.
Feb 18, 2015 | Honda EU3000iSAN EU 3000 Watt Generator w/...
How do u check to see if a ingnition switch is bad
Just put a jumper wire across the switch and try it. If it works, then the switch is bad.
Aug 31, 2014 | Honda EU3000iSAN EU 3000 Watt Generator w/...
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
Honda eu 3000 won't run, cleane bowl,cleaned filter. fresh oil new plug got spark, will run for 10 seconds, the will not crank again. wait 20 min. it like crank an run 10 seconds?
i usually do a quick test of a small few onzes of fuel down the plug hole and reinstal plag and see if i9 fire up and run for a lil bit. maybe 5 -10 seconds. now i know i have spark . most usually our wonderful fuel is the problem. its just nasty now. it can stick a needle to the seat. it can hold her open . one way ya flood out. the other ya starv out. give it a try.
Oct 15, 2012 | Honda 3000 Watt Portable Generator
The AC Plugs on my EU 3000 Generator are not working all of a sudden... I was using it and one plug and it stopped working, so I switched to the other outlet and after a while it stopped working also.
if no power on the plugs check for the cercuit breaker fuses and check for your load why it is tripping the circuit breaker the unit sbould not be overloaded
Jul 07, 2012 | Honda 3000 Watt Portable Generator
Honda 5000 generator clear oil out leaking thru air intake
There is supposed some oil in there. There is a tube to the carb intake that allows flow like a pcv valve
Oct 05, 2010 | Honda Mmd 5000 Watt Electric Start...
Honda 3000 eu no spark replace ing coil still no spark
Jul 21, 2010 | Honda 3000 Watt Portable Generator
Gas in the oil on my honda generator
Your needle/float is stuck, which will allow fuel to flow though the intake...past the piston..and into the crankcase. If has been awhile since you used it, most likely the gas has gummed up the insides of the carb. Otherwise, you may have had something get into the fuel bowl that is keeping the needle from closing. Best way to solve is to remove and clean the carb. Replace fuel filter if needed also.
Hope this helps
Mar 11, 2009 | Honda 3000 Watt Portable Generator
Honda 3000 Watt  Portable Generator Logo
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
