Question about Sharper Image Ionic Breeze® Quadra® Air Purifier
S1730N ionic breeze will not work after cleaning
The red indicator light came on,but after a cleaning the unit will not work. It turns on but the red light is still blinking. What do I need to do?
Bubbabear64
  • 2794 Answers
SOURCE: ionic breeze midi
Sharper Image Ionizers are no longer supported because they have recalled since they were proven to be innefective for cleaning the air and can harm people with breathing problems.
Here is a link on the Chapter 11 report
Here is an EPA report on ionizers
Posted on Jul 12, 2008
  • 4 Answers
SOURCE: Sharper Image Ionic Breeze GP S1719
I just typed in an msg on how I fixed mine. Im an old lady, and figured what the......... cant hurt. so check my msg here somewhere, and start taking out the screws. good luck, in the last couple of hours, ive fixed two of them, just cleaning the contacts. good luck to you.
Posted on Apr 23, 2009
SOURCE: ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Posted on Apr 25, 2009
  • 55 Answers
SOURCE: I have cleaned my unit but the red light stays on
Likely so these units usually put out ozone into the air in your home which is a known lung irritant. If you truly have indoor air quality issues the only way to properly attack it is through three steps
source control - what's causing it(uv lights to kill it usually)
ventilation - bring in fresh outdoor air and exhaust stale indoor air(ERVs and HRVs depending on your climate some dealers won't sell these if they don't offer it to you they are dumb find someone who does they are Recovery Ventilators)
filtration - a whole home filtration system (look to dealers who carry Lennox who is the only company with a 100% ozone free product line and the highest filtration rates available on the market "MERV 16" filters or Trane is ok as well as Carrier systems)
Posted on Sep 21, 2009
SOURCE: I have an ionic breeze quadra 3.0 the over due
I have exact same problem cleaned it but LED light remains on.
Posted on Nov 26, 2009
I have cleaned the unit thoroughly and the red cleaning light will not turn off on the ionic breeze quadra. what can i do? I bought this on ebay==never again?
blast bottom of unit with high pressure air from oxygen bottle. Wife has copd. Is on oxygen and I used her high pressure bottle. Works great. Unit works great.
Jul 14, 2010 | Sharper Image Professional Plus Ionic...
Ionic Breeze Midi Prof. Plus has red light on and won't work
When you cleaned everything did you also turn the whole unit upside down and gently shake to remove trapped dirt in the bottom of the unit. As for taking this unit apart to clean throughly there is no need. Just use some q-tips with 91% Isopropal alcohol not Rubbing alcohol to get to the small areas. Pay close attention to the small arrow shaped metal contact near the bottom of the unit. Make sure it is wiped clean and everything is completely dry. Plug unit back into power and the red button should turn green.
Mar 22, 2010 | Sharper Image Professional Plus Ionic...
Same problem as wpeed,, cleaned unit grid and red lamp cleaning indicator will not go off..any ideas will be appreciated.
sharper image recalled all their ionic breeze air purifiers because they dont work . check into the class action law suit
Dec 03, 2009 | Sharper Image Ionic Breeze 3.0 Air...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Is my Ionic Breeze Quadra hopelessly broken and beyond repair?
This unit can be replaced on ebay for around $45.00 which is under any labor cost to repair the unit you currently have. You can always post your unit for sale on ebay for parts.
Feb 19, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
"clean" light
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it.
Jul 31, 2008 | Sharper Image Professional Plus Ionic...
Ionic breeze midi
Jun 18, 2008 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
Sharper Image Ionic Breeze® Quadra® Air Purifier Logo
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
