Question about Mitsubishi VS-45607 45" Rear Projection Television
My ext inputs require a code. 0000 does not work. now what?
  • Mitsubishi Master
  • 5,138 Answers
I am Not sure what it is you are needing code to Mitsubishi TV ? Codes for remote unit 0093-0150-0178-1250 these are the codes i have for one 4 all remote.
Posted on Jan 03, 2009
Do you have the unlock code and need a way to input them them.
Input the code to your Sony stereo using the remote control handset
Press [+] on your stereo until you reach the first digit required then press [SEEK] to enter
Press [+] on your car radio until you reach the second digit required then press [SEEK] to enter
Press [+] until you reach the third digit required then press [SEEK] to enter
Press [+] on your stereo until you reach the fourth digit required then press [SEEK] to enter
The clock will be displayed once finished. Press the [SOURCE] key to switch the car radio on.
You can get the radio codes from the site
But you will have to pay for it.
Or worst case start at 0000-9999.
Hope this helps.
Mar 06, 2011 | Sony CDX-M1000TF CD Player
Mitsubishi VS-5004R
oh its a serious problem first find out the user manual and check whether there is any thing about this in it.
Dec 20, 2007 | Televison & Video
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here:
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
I was switch off my phone Micromax q3, and on it. the phone required input phone lock code, i am put 0000 phone code but it is not work. Pavan Gupta
micro max q3 mobile, i was on mobile the set is not open but the charger is input the charging socket then set is on please solve this problem.
Dec 09, 2010 | Computers & Internet
I need the code for bluetooth
In my box it says it is 6-0-0-0. hope this helps
Jan 02, 2010 | Polaroid PoGo Digital Photo Printer
Forgot pass key
almost blue devices pass key set on 0000 but if you are anable to access with this code then reset your device and use this code.
Dec 31, 2008 | Mad Catz PS3 Bluetooth® Headset Wireless...
My Mother has the VS-5003R big screen television that she purchased back in 1990. the television portion works fine but the ext-1 and ext-2 inputs are locked from a code that probably died with my father...
I have the same tv and same issue. I found chain of notes indicating that you can clear the lock by pressing 9-QV (two buttons) on the original remote at the same time. This works... however if you change the input again the EXT1 and EXT2 inputs will be locked again. It would be really nice if you can remove the lock feature completely.
Aug 07, 2008 | Mitsubishi Televison & Video
Accessing External Inputs Settings
you have to use the remote control for the tv not the dvr.
the dvr control likely cannot control the tv inputs programming unless you can program the correct code. and most new lcd panels don't have the correct codes for existing remotes
access using ext on the tv remote.
you may have to go into the menu and tell the tv what the ext is set to ie.. a channel or a input.
Feb 18, 2008 | Sony BRAVIA KDL-40V3000 Television
Pin code roe my H350
i forgot the code to my motorola h350 headset and wondering if you could give me it
Feb 15, 2008 | Motorola Mobility H350 Wireless Headset
Locked ext inputs
I'll give you the master reset, with set on, and from the remote hit Menu-1-2-7-0 this will bring up the Intilize screen and the word Initlize should be highlighted, if it is hit enter on the remote, this is the factory default settings so now if the set ask for a parental code it will be 0000
Nov 06, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
