Question about Viking VGSC366-6B Gas Kitchen Range
Oven barly heats up. It struggles to cook a pie.
When I turn on the oven, the burners are not going on at full heat. The left one will start up strong but simmer down to a warm little glow in about 20 seconds. Then the right some times will kick up to a med force but the left will go out completely. They are never on together in a cold start or half warm. I have replaced the dual thermal gas ct-rl valve but the problem is still there. The oven takes hours to heat and can not hold a 350 temp. Is there any other controller I can get to fix this poor oven?
  • THUGH Jan 11, 2009
    SAME PROBLEM ANY ASSISTANCE IS APPRECIATED
  • 59 Answers
Is the unit a self clean?
If not then the oven ignitors need to be replaced
Posted on Mar 08, 2009
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    LEFT REAR BURNER GETS HOT WHEN OVEN IS ON
    Look at this as an asset. The oven vents to that location. (gotta vent somewhere). You can use the heat to melt butter, keep something already cooked warm like the potatoes, dry pans after you've washed them... I like this feature!
    Sep 11, 2014 | Whirlpool Kitchen Ranges
    Maytag Range won't heat up oven or cook top
    you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
    Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
    Oven won heat unless burner is on
    Check the oven ignitor, it may be bad. See if you have power going to the ignitor.
    Oct 23, 2013 | Samsung RGSF5330DT Gas Kitchen Range
    The ovens turn on but do not get hot--it gets warm but the burners never turn red --- it takes 3 hours to cook a chicken
    If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jul 17, 2010 | Jenn-Air Ovens
    How to change the lower element on a delonghi AD 699 toaster oven?
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Oven not cooking at correct temperature & loses heat
    Had a similar issue - but my unit is eight years old. Turns out my issues were my oven ignitors were failing and one of the burners had corroded causing the flame to only light on one side. To fix I replaced two ignitors (apparently they are to be replaced every 3-5 years) and cleaned the burner with a brass wire brush. If you are handy the ignitors are easy to replace - one screw and two wires each. Burner was one screw to remove.
    Ceramic ignitors if wearing out can cause delayed lighting of the oven burners and/or reduce the gas flow - hence not heating up.
    That was my experience ....
    Jan 11, 2010 | Viking VGSC366-6B Gas Kitchen Range
    Microwave still runs but is not cooking food
    Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
    Sep 10, 2009 | Magic Chef CMV1000B Microwave Oven
    My Kenmore cooktop will not heat properly, all 4 burners. They turn on and heat a little bit, but the burner on lights do not light up and the burners do not heat to full temperature. I closed my oven...
    hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
    Feb 18, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
    Oven Burners not lighting completely
    It's the igniters. They increase in resistance as the elements age and decreases the current required to heat the spring element in the gas valve.
    Replace both igniters.
    Dec 23, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
    Viking VGSC366-6B Gas Kitchen Range Logo
    334 people viewed this question
    Top Viking Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
