Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Pulse all 3 of my phones are suddenly in the pulse mode, and I cannot find my manuals.. I need to reset them back to touch tone.. not pulse
  • reeseroy Jan 03, 2009
    I found the solution.. same one as the person who was looking for the manuals.. that is a great tip, you can just download any uniden phone manual... thanks
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Jan 15, 2013
SOURCE: how to switch phone to tone
I got the same problem. I searched everywhere and got the manual at Tomson. Since it is so painful to me, I would take the pain to write this and share to you. Now, for GE 2-6920R, it's easy:
Tone:
1. Make sure the phone is OFF
2. Press and hole the CHAN button for 2 seconds until the phone beeps
3. Press TONE* button. The phone will phone again to confirm the change.
Posted on Mar 09, 2008
SOURCE: ONETEL PHONE
we have a ot150 phone but when some one rings it does not ring straight away.it will start to ring when it allmost time for the answer phone to kick in thanks mr williams
Posted on Apr 13, 2008
  • 3 Answers
SOURCE: pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Posted on Aug 09, 2008
SOURCE: Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Posted on Jan 23, 2009
smartr10U
  • 1305 Answers
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Posted on Jun 05, 2009
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Model UNIDEN UCIS-225 - Phone suddenly dials like a rotary phone. Does anyone know how to make it return to the non-rotary dialing?
two places<br /> 1. Manual switch on back of phone Tone or Pulse<br /> 2. Menu-Set Dial Mode - DTMF (tone) or Pulse
Aug 05, 2010 | Uniden Lands Phones
I dont have an owners manual and just wondering how to switch the setting from pulse to tone
  3. Scroll to highlight Tone.
If you ever need to change the dial mode back to pulse dialing, follow the same procedure, but select Pulse in step 3
Jan 09, 2010 | Uniden DECT 6.0 Cordless Telephone...
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Pulse and tone
in GE:
TONE/PULSE DIALING
Mar 16, 2008 | Lands Phones
From Pulse to tone
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Aug 31, 2007 | GEH5450 Cordless Phone
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Jan 11, 2007 | GE 29439GE2 Corded Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
42 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
